m3 back seat in a 325is.. seat belt receivers?
  • Julien
    • 7471
    Has anyone come up with a simple solution to get the belt buckle receivers to sit nicely in an m3 back seat in a narrow body car?
    Currently the receivers are bolted on each side of the middle of the seat to allow for a third person. They don't quite reach the m3 seat's plastic holders. Other than drilling a new hole in my floorboard, I can't think of a way to make it all fit nicely.
    Any ideas?
    Build Threads:
  • Jokester
    • Sep 2016
    • 1818
    I think Staszek is running a rear m3 seat in his coupe. I may be wrong, but it seems to me he has m3 seats based on his build thread.
    • AndrewBird
      The Mad Scientist
      • 11898
      According to RealOEM, M3 buckles are the same as non-M3, so they must be bolted into a different spot.
      • e30austin
        • 15382
        IIRC, I swapped my seat belt buckles from side to side, got them to fit in place (barely) and cut off the ones I did not need. Been a long time, so I don't remember that well.
        • E30SPDFRK
          • 5715
          The M3 has a center mounting hole in the chassis and uses the normal e30 dual receiver piece. If you do drill a hole, be sure to add reinforcement to that area, because it's just a single layer on non-M's.
          Byron
          Leichtbau
          • Julien
            • 7471
            Hmm, is it easy to access back there or are you basically on top of the rear subframe?
            Build Threads:
            • E30SPDFRK
              • 5715
              Its just to the right of the brake line T, directly over the differential hump in the subframe.
              Went and took a picture of an M3 I'm doing some rust cleanup on
              Byron
              Leichtbau
