Heated seats retrofit with aftermarket pads?
  • arkadur
    • Jun 2018
    • 5
    Hello.
    I got the oem loom with the switches without the heating mats.
    Waeco has great kits in great price.
    Did someone ever tried to fit between them or I need to go with the oem heating pads thats are way expensive?
    There is another option?
    Thanks
    Sent from my SM-N950F using Tapatalk
  • rzmoser
    • Feb 2016
    • 106
    I bought this heated seat kit (the "High-low round switch 2 seats") in 2015 and wired it up to the stock switches. After four years it still works great! It gets too hot for comfort on the highest setting for me. I just cut off the provided switches, and used a multimeter to make sure the wires from the e30 switches were putting out the same outputs. The kit's switches and the e30 ones worked the same, they even light up like they should.
    • Mwishlist
      • Jul 2013
      • 505
      This, I did the exact same thing, three or four years now and still going strong.
      Thank god, R3V was getting boring since the ginger kid wrecked his car. - Stonea
      • bradnic
        • Jul 2012
        • 3552
        fyi the OEM pads aren't very expensive, but totally get the appeal of aftermarket. you can't see the darn things anyway, but as posted above you may have temp issues.
        HOWTOs:
        DB vert plastic bumpers
        OEM Keys
        MTech1 docs
        88 ix Lach/Card
        91 ic Calypso 3.1
        86 Cosmo 2.7
        OEM+ or bust!
        • rzmoser
          • Feb 2016
          • 106
          I wouldn't say temperature is an issue for the Amazon ones I got, they're perfect when its 55 out and I'm driving with the top down. But long trips with the heat on they make my back sweaty, so I'd say they're perfect. Not hot enough to burn, but hot enough that the lower setting is good.
          Also, the switch doesn't control the temperature. The low and high setting are both 12v, the switch just sends the 12v signal to the relay box that comes with the kit. The switches with the kit works the same as the OEM switches, either the high or low wire is given 12 volts, its never both.
          • E30andy
            • Aug 2016
            • 504
            rzmoser.....can you comment on how you attached the heated seat elements you got from Amazon to to the seat foam? Trying to figure out the best way to attach the OEM elements I bought to retrofit into my non-heated sport seats.
            Thanks!
            89 325ix coupe Diamondschwartz
            1994 Mazda Miata
            • E30andy
              • Aug 2016
              • 504
              Thanks for your reply in the ix forum rzmoser! Got my answer.
              1994 Mazda Miata
