Issue with AC knob control/switch
  • e30mitch
    • Mar 2016
    • 57
    Hi Everyone,
    So a few days ago I took out my whole radio/hvac trim to have it replaced with a better one. Unfortunately, after I finished installing it - my ac knob (the one that regulates how strong the air comes out) started to act weird. Now, the 1 setting blows like a 4, and the 4 like a 1, and the 2&3 settings do not blow at all. It also doesn't feel the same when changing settings, it slides more...weird.
    Has someone experienced this before that can guide me in the right direction? I'm 99.99% sure I installed it back correctly...
  • taiwanesekid05
    • Feb 2017
    • 25
    Sounds like the blower motor fuse blew. Check (I think?) the #20 fuse to see if its blown.
    • jeffnhiscars
      • Jun 2011
      • 6011
      If it blows at all it's not the fuse. Did you remove the wires f on the switch by chance ?
      Alice the Time Capsule
      • e30mitch
        • Mar 2016
        • 57
        No I did not remove/cut any wires...all i did was remove the switch from the back...
        • Ceeker
          • Sep 2009
          • 2821
          make sure you have the correct plug for the switch..it's easy to swap sockets around.
