Snapped the Rear view mirror
  • Jean
    • 18228
    I removed the rear-view view mirrow to clean it and when I tried to put it back on it's pivot point/ball the whole assembly snapped from the headliner area!!!
    Did I just break it, or is there a trick to this ? There is a spring on there, but I don't understand how this work and how to put it back in there
    Mine is just a basic mirror , #1 in http://www.realoem.com/bmw/showparts...68&hg=51&fg=40
    Help
  • RedHoodRidah
    • Feb 2006
    • 1096
    I doubt you broke it, its pretty hard. To get it back on the car is pretty hard though because it needs a bit of pressure. Try to get one side in first and then get like a hammer with a rubber handle on the other side and just push it in, that how I got mine on.
    OT: I got a mirror for sale if anything.
    92 Granite Silver Vert
    M60B40 5spd
    • PiercedE30
      • Apr 2005
      • 4220
      Here's what I did.....take some little, i mean TINY, zip ties. Use a set of channel locks to compress the pins and the spring enough to put two of those little zip ties in, one on each side. Then, put the mirror up in it's little spot, force it if need be, pull out zip ties while holding mirror in place (to make sure it doesn't come down in the process). Easy as pie.
      My 2.9L Build!
      • Jean
        • 18228
        Correct, it doesn't look broken but I can't see / feel where it needs to snap in and will try the zip tie method. The only thing it broke when it came off was the corner of the cardboard type material used infront of the headliner near the windshield but I don't think it mounts to that...
        • Jean
          • 18228
          Ok, got the mirror base attached back to the car.. What's the secret or trick to getting the mirror itself on the damn ball ? I tried different angles and it doesn't wan't to slip on.
          • Jean
            • 18228
            I feel so dumb, i just won't go on the damn mount... I wonder if it's broken. :(
            • Dominic49
              • Feb 2007
              • 1373
              i had to have a friend help me and we both pushed hard as helkl... damn thing needs 150lbs pushing it
              • RedHoodRidah
                • Feb 2006
                • 1096
                For some reason mine goes on with ease when i have the right side mounted and then push on the left. When I do the opposite......I pooop lol
                M60B40 5spd
                • Jean
                  • 18228
                  I found out it's easier to mount the mirror on the metal base, and then pop the base back in it's place.
                  • RedHoodRidah
                    • Feb 2006
                    • 1096
                    Awesomeness.
                    M60B40 5spd
