Cracks in the dash
  • ian e30 318is
    • Mar 2007
    • 1809
    Cracks in the dash
    The cracks in my dash are getting really bad. What should I do? I tried filling them in but so far they are just getting worse. anyone know of a cover I can use or should i try to find a new dashboard?
    1991 LS1 Swapped 318is
    Instagram:
    https://instagram.com/saltybeast/
    LS Build Thread:
    https://www.r3vlimited.com/board/for...s-e30-ls1-swap
  • kencopperwheat
    King of Kegstands
    • 14396
    New dashboard.
    /thread
    Originally posted by Gruelius
    • Mr.SWISS
      • Nov 2005
      • 1251
      What filler did you use?
      Originally posted by 325Projectz
      don't listen to the diagram... listen to mr. swiss.
      :nice:
      • backtrail69
        • Jul 2005
        • 4471
        Originally posted by kencopperwheat
        New dashboard.
        /thread
        +1 Dash cracks can't really be filled and them look nice...
        :: PNW Crew ::
        '87 325 4dr, '74 2002
        • ian e30 318is
          • Mar 2007
          • 1809
          i dont remember what kind but i just did it as a quick fix. nothing permanent. i want to put in a new dash but was wondering how much it would be for someone to install it because i have no idea how to do it. Also i was wondering if anyone has tried a cover like the one on bavauto.
          Instagram:
          LS Build Thread:
          • Mastrcruse
            • Sep 2005
            • 5340
            Looks like a lot of time is what it takes
            • ian e30 318is
              • Mar 2007
              • 1809
              haha. damn...looks like i might be spending a few weekends in the summer working on it.
              Instagram:
              LS Build Thread:
              • hendrixvodu
                • Jan 2007
                • 2514
                ive removed and installed 4 e30 dashes its not bad....the only hard part is the
                temp dials and controls....but if you take them apart right its not too bad at all....just watch the screw under the column for the dash..i alway forget it....putting it in requires two people....if you do it on your own it sucks....but i have done it....also label all your screw...and switches....or just leave the switches in...all together...maybe a 2-3 hour job
                -His-
                87 e30 325i
                87 e24 m6
                05 e83 x3
                94 e32 740i 5spd
                -Hers-
                89 e30 325i
                18 f48 x1
                • ian e30 318is
                  • Mar 2007
                  • 1809
                  alright cool. thanks. i need to start searching for a nice dash soon.
                  Instagram:
                  LS Build Thread:
                    • 37833
                    I got a nice dash for $20 somehow. Took an hour or so to do the swap.
                    Grover Beach, California
                    BimmerHeads.com
                    • browntown
                      • Jun 2004
                      • 3524
                      before I found a crackless dash at the boneyard, I contemplated using the plastic/vinyl welding system they sell at harbor freight. I was going to be the guinea pig, but like mr 325, got one for 20$. You can be that test bed..
                      • dlmpsy
                        • Sep 2006
                        • 189
                        I've seen dash covers for about $90 that look pretty good, I think Bavarian auto has them.
                        • ian e30 318is
                          • Mar 2007
                          • 1809
                          did you get the $20 dash at a local junkyard??
                          Instagram:
                          LS Build Thread:
                          • browntown
                            • Jun 2004
                            • 3524
                            yup
                            • maco325e
                              • May 2007
                              • 177
                              mine $15 at the junkyard
