Vader seat pics/install
  • bostonbmw
    • Nov 2004
    • 429
    I am looking for info/photos on this swap. Thanks Brian
  • BMW_TUNER
    • Jul 2006
    • 1386
    I will try to get some pics up soon. I will be moving them into my new E30 in a few days so I will take pictures of the brakets. and the seats.
    1989 332IS -S-Fiddy Four-Some weight removed.
    5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
    • stevofthahill
      • Apr 2005
      • 2468
      there ya go
      • ldsbeaker
        • Aug 2004
        • 3098
        wow, is that all? I'm on it! Thanks for the link!
        Slicktop City!
        • stevofthahill
          • Apr 2005
          • 2468
          Np at all, the owner of that website is a good friend of mine.
          • bostonbmw
            • Nov 2004
            • 429
            I am interested to see what people do with the factory seat belts since you have to remove the slider bar .
            • Jparkr
              HR Admin
              • Jan 2006
              • 3494
              in my swap i used an exhaust hanger and just drilled it into the floor with reinforcements that way the lap belt was still removable but also safe and succure
              1987 PRO-3 car /1990 325is (2.7i Concours)
              • eighteight325is
                • Apr 2006
                • 204
                I don't have any good pics but I have Vaders in my car. I made the brackets out of 1/4 inch steel rather than drilling the unibody which I have heard others have done.
                I bolted the belts to the brackets I fabricated (which are bolted to the floor using the stock seat belt holds) using 1/4 inch angle iron and grade 8 bolts making sure not to kink the seat belt webbing (nylong webbing is strongest when it is not folded or kinked).
                I am currently trying to source some sedan seat belts because I believe that bolting the end of the lap belt to the B-pillar using the stock mounting point for the slider bar is probably better overall.
                • BMW_TUNER
                  • Jul 2006
                  • 1386
                  I kept the bars in place.
                  • matias9
                    • Aug 2011
                    • 86
                    the link doesnt work :(, im having some troubles :S , ive got the brackets and works great, but the problems are the seatbelt When you put it in without modifing the nipple . the seatbelt sensor from the car came 2 wires to the connector and the vares has a 3 wires connector so im confused .this seat has the pyrotechnic protection ? any one knows how i can make it work? which wire must be connected?.
                    ive got a 4dr
