good carpet cleaning products?
  • E30 Wagen
    • Jul 2005
    • 3434
    What are some of the best carpet cleaning products out there?
    thanks
    My Feedback
  • twothrees
    • 252
    If you carpet is really bad, remove it and go rent a Rug Doctor from Lowes/Home Dept. It did wonders on mine.
    • 330SMG
      • Feb 2007
      • 172
      If it is just dirt, soda and other stains the Blue Coral stuff in a can works really well. I removed soda from my blue carpet. It foams up so the underside of the carpet does not get wet.
      1989 Cirrus Blau coupe Racing Dynamics wheels and a Volvo Spoiler.
      • Cobra Jet
        • Apr 2008
        • 278
        You want something that will REALLY WORK on any carpet? Try this stuff out, then report back... I've used this numerous times both in cars & @ home and it's the ONLY product that I will use for carpet cleaning anywhere...
        FOLEX® Instant Carpet Spot Remover is a trusted brand for over 50 years and is known the best carpet stain remover.
        You can buy it @ Home Depot and I think Lowes may have it too.
        Trust me - it WORKS. Just spray your spots or soiled areas, let it sit for about 5-10 minutes, then go back, spray a little more, use a scrub brush to stir up the soiled area, then use whatever carpet cleaner or upholstery cleaner machine that you have to suck up the remnants.
        • seattlebest
          • Sep 2012
          • 1
          I used Stanley Steemer Carpet Cleaner. They were a little expensive, but they did a great job and I think it was worth it!
          carpet cleaning seattle yelp
          • AndrewBird
            The Mad Scientist
            • 11898
            If it is REALLY bad, take it to a spray bay car wash and take the pressure washer to it. Works amazingly well.
            I've used this stuff a lot with good results:
            I even use it in the house.
            • jeffnhiscars
              • Jun 2011
              • 6011
              Would you suggest removing it from the car first ?
              Alice the Time Capsule
              • Tanktheory
                • May 2011
                • 432
                Nope. :)
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  I figured that was kind of a given.
                  And if you think I'm joking about pressure washing it, I'm not. Josh and I (Janderson) did his carpet like this and we got the idea from Luke (StereoInstaller1). Came out great. Just have to let it dry for a few days.
                  • Bimmerguy91
                    • Jul 2012
                    • 982
                    If its really nasty heres what I did. Pull it out vacuum it, soak it in purple power and scotch carpet cleaner and scrub it with a bristle brush. Then pressure wash the hell out of it and let it dry. Took a carpet that was maybe a 3/10 to a 8.5/10
                    • 5Toes
                      • 9836
                      flash interior cleaner works pretty good. Some stains it just cant pull out though.
                      got baked on coca cola off a headliner really easily!
                      • e34john
                        • Apr 2006
                        • 3599
                        Thats what I used. Some Purple Power if you have grease or oil stains, then Blue Coral the entire carpet.
                        • tonystrength
                          • Feb 2013
                          • 2
                          Originally posted by Cobra Jet
                          You want something that will REALLY WORK on any carpet? Try this stuff out, then report back... I've used this numerous times both in cars & @ home and it's the ONLY Carpet cleaning brisbane product that I will use for carpet cleaning anywhere...
                          Trust me - it WORKS. Just spray your spots or soiled areas, let it sit for about 5-10 minutes, then go back, spray a little more, use a scrub brush to stir up the soiled area, then use whatever Carpet Cleaning Sunshine Coast or upholstery cleaner machine that you have to suck up the remnants.
                          Hello guys just responding to this old thread. My car carpets looks dirty and dull and someone has recommended steam cleaning. What are your opinion guys? Is there any other way to clean them which is more effective and time saving.
                          • e30trooper
                            • 11576
                            Did you read anything above?
