Where does THIS go?
  • rodrigo
    • Aug 2007
    • 923
    Where does THIS go?
    I pulled the HVAC panel out and the instrument cluster, radio, glove box, ECU, etc, all out in one day..put everything in a box...I have these 2 screws left over (total n00bleness!!) and I have NO clue where they go.
    can you guys help??
  • kronus
    • Apr 2008
    • 13020
    They look like the screws that mount the ashtray and cigarette lighter to the console, but I bet a ton of those screws are similar.
    cars beep boop
    • rodrigo
      • Aug 2007
      • 923
      I dont think its those...those are black...I have those. These are much bigger...like #3 phillips tip big.
      I think they were from the innards of the HVAC area. I just removed the HVAC panel to replace and left the controls in place.
      • Jean
        • 18228
        Correct.
        The ones you listed could be from the sides of the HVAC box, there are two plastic "guides" to feed the air to the back seat passengers on each side of the blower/heater box.
        • rodrigo
          • Aug 2007
          • 923
          you mean the accordian thingies that tie slip into the channels on the floor? Those just popped in...I didnt notice any hardware except the 10mm plactic nuts they get tightened down with on the floor and transmission tunnel of the car.
          • twistednut
            • Nov 2007
            • 272
            I believe they hold the HVAC panel in place through the three air direction slide switches.
            what you did to this car is like getting a supermodel naked and willing to do anything you please. now here you are faced with ths once in a lifetime opportunity and then you squander it by making her fuck you in the butt with a 24" strap on. you are a sad, silly little boy.
            • rodrigo
              • Aug 2007
              • 923
              I have the HVAC panel back in the car...and 4 screws in the three slide area...
              i will look into all of your suggestions and post back.
              • rodrigo
                • Aug 2007
                • 923
                For the record: the steering columnn covers clasp together right at the base of the steering wheel.
                thanks for your help, guys!
