City light, Canadian headlight ?
  • thedeal
    • 643
    Here is the deal, I bought a canadian car (lowbeams on whenever the ignition is on) w/ sealed beams. I am in the process of hooking up my euro ellipsoids. How can I hook up my city lights to be on when the ignition is on but have my low beams off until I pull the light switch?
    Thanks is Advance,
    thedeal
  • theox69
    • May 2008
    • 1732
    I'm in the same boat as you.
    You'll have to rewire your headlights like the way they came on US cars.
    you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
    • Spaz
      Crazy Canuck
      • 2276
      Your headlights go out when you pull it to the middle or "running lights" spot.
      Then you can wire your city lights off of the side markers.
      I always drive with my lights in that spot until i need to put on my headlights.
      Cam .W '91 325is
      Spaz's 1991 Alpine White???? S52 Build Thread...
      • guibo09
        • Dec 2008
        • 834
        but arent your dash lights always on? that annoys the hell out of me
        90 E30 325i
        • Spaz
          Crazy Canuck
          • 2276
          They are, you can just turn the dial down and they become nearly invisible during the day.
          -Cam
          Cam .W '91 325is
          • guibo09
            • Dec 2008
            • 834
            -Cam
            i cant live with having to do that. i think i might be able to find the diode that converts canadian cars to running lights. disconnecting it should turn them off and be exactly like american cars.
            90 E30 325i
            • theox69
              • May 2008
              • 1732
              I don't think they use a diode...
              • guibo09
                • Dec 2008
                • 834
                thats what i saw in a electrical schematic for a canadian cars. what do you think they use?
                90 E30 325i
                • theox69
                  • May 2008
                  • 1732
                  Oh..
                  Well then I might be completely lost with my car.
                  It's a '91 US-Spec car, imported to Montreal in '96 and they wired my ignition wire and low-beam wires together.
                  And I need to bring it back to stock...
                  • guibo09
                    • Dec 2008
                    • 834
                    Oh..
                    yeah thats completely different. we're talking canadian spec cars.
                    90 E30 325i
                    • theox69
                      • May 2008
                      • 1732
                      completely disregard my input then. sorry :)
                      • Spaz
                        Crazy Canuck
                        • 2276
                        I've heard its a relay used only on Canadians cars, I cannot confirm/deny this though. Although i suspect this is the case seeing as the wiring on all my cars match us spec e30's and wiring diagrams and as far as i know there are no country specific wiring diagrams that I've seen.
                        -Cam
                        Cam .W '91 325is
                        • SFGadgetGuy
                          • Jul 2008
                          • 934
                          When I used to live in Vancouver BC and worked in a shop we use to install DRL in non DRL cars to meet inspection with a DRL module.
                          Might want to check under your dash and see if there is a module spliced into the switch wiring.
