BRAKE LIGHTS ARE NOT WORKING WTF!!?!?!?!?!
  • B2ThaZiZza
    • Aug 2004
    • 614
    Ok all my brake lights and reverselights are brand new so is the reverse sensor light, when i turn the headlights on they are lit but the brake lights dont light up when i press on the brake they dont light up i checked everything but they stil dont light up what is wrong?
    (ALSO IT HAS BEEN RAINING)
  • bmwguru007
    • 561
    For your benefit, in the future you should post technical questions in the general technical section. In regards to your problem, start by checking your fuses. If they are ok take a look at your brake light switch.
    • Drake
      • Apr 2004
      • 67
      Prob the sensor on the brake pedal
      • B2ThaZiZza
        • Aug 2004
        • 614
        sorry im in a state of panic and i forgot, also i checked all of the fuses and the they are fine and dandy, as for the brake light switch where is that at?
        • M-technik-3
          • 18946
          Check to see if the cicuit is complete.
          • e30Matt
            • 5077
            Brake pedal switch is located behind the brake pedal arm under the dash.
            • Ryan Stewart
              I Love Miatas
              • 8978
              Put your car in your profile, sig, or post. There are subtle differences between models. On early models the switch is the only likely solution.
              Im now E30less.
              • B2ThaZiZza
                • Aug 2004
                • 614
                Ok thanks guys, oh by the way i have a 1991 318is and the brake switch for the lights was broke, i fixed it so now its all good. thanks for the help.
