Brand new HID Bulb went out
  • ck_taft325is
    • Sep 2007
    • 6880
    DDMtuning's 55w Apexcone 6000k HID kit. Pass. side took a crap on me out of no where. Working, turned the car of, turned it on 20 minutes later and it's been inop. ever since. Any suggestions of where to check first? Bulb and work my way back through the wiring?
    Something to note: Both drivers and pass. ballasts made a bit of a humming (from my Electrician back ground, not totally un-common with ballasts) and the pass. after it went out, makes absolutely no noise now.
    My guesses are that it's on the wiring side. Just curious if anyone else encountered this and could shed some "light" ... (har har har)
    Need a part? PM me.
  • BigSam
    • Jun 2008
    • 168
    Try flipping the OEM BMW wire where it goes into the wiring harness on its way to the ballast, that solved my issue, assuming of course that your bulb isn't broken.
    Also, keep in mind that you should never touch the bulb, the oil from your skin can get on the bulb and cause a hot spot, often leading to the bulb shorting or breaking.
    • BingM3
      • 863
      They give a year or more warranty, just have them send a replacement, try placing the bulb on the other side and see if it works
      • gearheadE30
        • Jun 2007
        • 3734
        I'm going to bet you blew the fuse. They have to be upgraded to 10 amps, especially with 55 watts.
        Project M42 Turbo
        • 5KWattson
          • Apr 2009
          • 809
          i was under the impression that the 55W kits used less amps then the 35W kit...cant remember who or where it was said though
          "God created turbo lag to give V8's a chance" Taylor D.
          • TheRooster
            • Jan 2010
            • 168
            Same thing happen to me.. When i install them they were both working(yesterday night). I had the stock fuses in there. Then today I turn them on and the pass side wasnt working. I upgrade the fuse and still didnt work. My bulb is still good
            • TheRooster
              • Jan 2010
              • 168
              ok just a update.... I swap my pass side ballast with the driver side ballast. Then all of a sudden both of them work and all i did was swap them. Weird and thoughts? Im just happy it works and dont have to deal with calling them.
              • ck_taft325is
                • Sep 2007
                • 6880
                One of my ballast's wasn't/isn't working. I ordered another kit in case I can't get this one to work with what you tried. I only switched the working side to the inop. side to check the bulb. I'll try putting the bad ballast on the other side to check it once more.
                Need a part? PM me.
                • Fidhle007
                  I can fly, motherfucker
                  • Oct 2005
                  • 7209
                  Just swap your good working bulb onto the dead side and that will tell you if it's a bulb issue or if it goes deeper. Assuming it's not the bulb (it's usually not the bulb) switch the ballasts to see it's the ballast. If the same side side stays out regardless of which ballast you use you have wiring issues, if the lights out side switches, it's the ballast. Fuses need to be upgraded regardless though, the HID kits don't use much amperage while running but that initial ignition spark takes quite a toll...
                  '89 325is S50 Track Montser
                  '04 X5 Daily/Tow Vehicle
                  http://www.avarestoration.com
                  http://www.myspace.com/brendanfiddle
                  Click here if you want to be my zombie slave...
                  http://www.youtube.com/user/Fidhle007
                  • BigSam
                    • Jun 2008
                    • 168
                    FWIW, I am running 55w HID's in my low beams and 35w HID's in my fog lights, both on stock fuses and no issues have come up yet.
                    • TheRooster
                      • Jan 2010
                      • 168
                      updates?
                      • gearheadE30
                        • Jun 2007
                        • 3734
                        @BigSam-Same here, but after a few months one of the lowbeam fuses blew on startup.
                        Project M42 Turbo
                          • 37833
                          I've been running the 55w kit for a LONG time without upgraded fuses.
                          Grover Beach, California
                          BimmerHeads.com
