LED gauge lighting
  • evilnickwong
    • Aug 2007
    • 302
    #31
    I used these kind of LEDs for my cluster:
    You need these with side facing LEDs since that's how the cluster is lit up (from the sides). Had to remove the orangle bulb covers since these are abit taller than normal incandescents, however, the color at night is still the same. Only that the odometer numbers follow the LED color which in my case are white.
    Not super bright, but I like the fact that they are LEDs and are not generating loads of heat in the fragile/old cluster.
    • riverdale21
      • Mar 2004
      • 786
      #32
      Do you have any pictures of your cluster with the LEDs?
      • evilnickwong
        • Aug 2007
        • 302
        #33
        Not at the moment. I'll be home in about a week's time if you want one.
        • jakkerd
          • Jun 2010
          • 43
          #34
          Originally posted by Supadave
          [ATTACH]36643[/ATTACH]
          Sorry for the sorry pic. (bullshit phone) It was taken in the middle of the day. I take some at night with a a real camra later
          If they make that for euro gauges, i would buy them. Looks good.
          • browntown
            • Jun 2004
            • 3524
            #35
            Wow, thats pretty cool. electroluminescent gauges. why didn't George Graves make these first? They would have been cheaper and with great documentation.
            • nikole95
              • Jan 2011
              • 1
              #36
              Originally posted by Freshwagon
              I wanna slap a set of indiglo faces in there. Already removed the orange plastic so the different colored lights don´t interfere with each other.
              how to get free wii games
              free wii games
              • GunMetalGrey
                • Dec 2010
                • 1499
                #37
                I have put in a set of red LED's in my car instead of the amber LED's. They are a bit brighter, and cannot be changed a ton for brightness but you can change the low end a bit, but they are a really nice red and I left the lower amber deflecters in, so they don't bother your eyes much at all.
                Pictures in a couple of hours.
                • melloh
                  • Sep 2006
                  • 19
                  #38
                  Hi all. I wanted to revive this rather than to start a new thread (and get hammered by admin)...
                  I have my dash out right now and I'm in the process of replacing ALL bulbs before I put it together again. I would like to replace w/ LED - right now leaning towards removing all orange filters and replacing with red (otherwise keeping it white).
                  Could someone lend their expeirience and knowledge to give a full shopping list??
                  2721 replacement for cluster, correct?
                  is this the same for the HVAC and other bulbs?
                  How many bulbs in total?
                  Thank you!!!
                  Cheers,
                  Henry
                  • TG Goose
                    • Jul 2011
                    • 234
                    #39
                    I put in 6 LED, 194 bulbs. Way brighter, produces no heat. Bought them from superbrightleds.com
                    ______________________________________
                    1984 LSB 318i - Sold
                    1986 325i - Motor Swapped Track Car Project
                    1995 318ti - Sold
                    1999 540iA - Daily Driver
                    • melloh
                      • Sep 2006
                      • 19
                      #40
                      Awesome! Thanks so much, Goose.
                      So 6 #194 for non-cluster lights
                      2 #2721 replacements for cluster ( plan on removing the orange plasic an getting red or amber bulbs).
                      I know the cluster 2721 need to be 360 deg angle, but do you happen to recall which #194 replacements you used? There are so darn many options! I just worry about not getting enough "angle-age" and having shadows. There is also "polarized" or "non-polarized." I am assuming "non-polarized"?
                      This is what I'm looking at - hopefully someone can provide feedback [Note: brightess is not an issue for me since I usually have them pretty dim - I just want even/full lighting]
                      LED replacement bulbs can fit numerous vehicle applications such as vanity lights, map lights, dome lights, glove box lights, and gauge lights as well as landscape applications. This 194 bulb replaces a variety of traditional bulbs including 168 and T10 bulbs. It has 4 radially mounted LEDs aiming outward from the sides and 1 high-flux LED on top. LEDs create a 220° viewing angle. Miniature wedge base for easy plug-and-play installation. The energy-efficient bulb operates with in a wide 9-14.5V DC range and is designed to last 8 times longer on your car, truck, SUV, or van than incandescent bulbs.
                      Most likely candidate here...
                      This 194 LED light bulb is perfect for vehicle, RV, and boat applications. It replaces several traditional bulbs, including 168 and T10 bulbs. The single LED bulb is available with a 90- or 120-degree beam angle. A miniature wedge base allows for easy plug-and-play installation. The energy-efficient bulb operates within a wide 9-14.5 VDC range and is designed to last up to 10,000 hours— 8 times longer than incandescent bulbs. Color options included cool white, UV blacklight, blue, green, amber, and red. Available as a single bulb or in a 10- or 20-pack.
                      Thanks again for your help and patience with my 'noob' questions. I just don't want to have to waste money and time in getting the wrong thing.
                      • Aerton
                        • Oct 2006
                        • 729
                        #41
                        Ok subscribed, all my dash lights are out right now, my alternator sent a spike and left me with no lighting. I'll be home for a week by the end of August and plan to do the bulb swap. Melloh keep us posted and show us pics.
                        Thanks
                        WTB-Strut Bar
                        • melloh
                          • Sep 2006
                          • 19
                          #42
                          Well, first thing to note is that I have the #'s reversed - the 194 is for the 2 large bulbs in the Cluster. The 2721 are the small ones.
                          I got my order from superbrightleds.com.
                          The Festoon bulb they have for our car is the wrong size - too long (I was lazy and just made it fit, though). Don't use their vehicle selector to pick the festoon bulbs.
                          Also, NONE of the ones I got work with the dimmer switch. That sucks.... I just emailed superlumination/autolumination.com to see if theirs will work.
                          This is what I ordered
                          2721
                          LED replacement bulbs can fit numerous vehicle applications such as vanity lights, dome lights, map lights, dashboard lights, instrument panel lights and gauge lights. This 74 bulb replaces a variety of traditional bulbs including 74, 103 and 118 bulbs. It has 3 LEDs (3528 SMD)—1 top-mounted and 2 front- and back-mounted that create a 360° viewing angle for better, allover light emission with reduced hot spots. Miniature wedge base for easy plug-and-play installation. Energy-efficient bulb operates with in a wide 10-16V DC range and is designed to last 30,000 hours on your car, truck, SUV, or van—25 times longer than incandescent bulbs. Available in cool and warm white, blue, green, amber and red.
                          194
                          Super Bright LEDs is one of the largest online retailers of LED lighting for commercial and residential uses. Enjoy free/same-day shipping on qualifying orders!
                          Be sure to check that they turn on because the ones I got are polarized - I had to flip a few over. I also had to mod the mounts a bit to make more solid contact by slightly bending the metal tabs. A couple I had to file down rough edges of the LED circuit board.
                          No pics yet... and when I do, it will be with a cell phone unfortunately!
