Anyone have ellipsoid projector fog lamps?
  • Andrew325is
    • Jan 2008
    • 1212
    This is probably retarded but I've never actually seen these. Anyone know the BMW part number?
    Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
  • e34john
    • Apr 2006
    • 3599
    Aren't they all like that and that is just one that doesn't have 20 years worth of sand blasting.
    • td325ic
      • Feb 2006
      • 786
      woah, that's pretty interesting. Never new they made those for e30s.
      A lot of e34's and e32's come stock with ellipsoid foglights with H1 bulbs, I've always planned on doing a retro-fit someday into an e30 foglight housing
      It's cool to see that was a factory option, but I've never seen any e30 with them, euro or otherwise for the 4+ years I've been on these forums.
      • ethrty
        • Nov 2009
        • 342
        i live outside the US (read: euroland) and never seen those either. custom retro fit? even brand new from BMW arent like that
        • theox69
          • May 2008
          • 1732
          That's what I thought too...
          you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
          • richardkeith97
            • 1693
            i c them on ebay all the time
            • nrubenstein
              • 3148
              That's a different projector from the one that I've seen in the normal ellipsoid fogs. A round lens is a significant change from an oval one.
              I've never seen one like that in the wild.
              2002 BMW M3 Alpinweiß/Black
              1999 323i GTS2 Alpinweiß
              1995 M3 Dakargelb/Black
              - S50B32/S6S420G/3.91
              1990 325is Brilliantrot/Tan
              1989 M3 Alpinweiß/Black
              • Andrew325is
                • Jan 2008
                • 1212
                They are definitely factory. This is from an original German brochure.
                • Raxe
                  • 5346
                  Weird, never seen those before. The stock projector fogs are oval.
                  • straight6pwr
                    • Sep 2004
                    • 3450
                    from what i can tell, those are the normal oval 'projectors' fogs. they are covered with some kind of paint on the back of the lens or a plastic shield (like the plastic ring inside the projector headlight) which has a round opening around the main part of the projector where the light is emitted.
                    notice how the fog light is a much lighter color than normal? on my car you can see the stock fogs are nearly as dark as smoked headlights. the ones the OP posted are as light as stock headlights.
                    so they ARE different cosmetically, but functionally the same. anyone could make there fog look like this if they popped off the lenses.
                    • dnova89
                      • Aug 2009
                      • 851
                      I need to get myself a set of ellipsoid fogs. My stock ones are cracked and they are non ellipsoid, so I might as well upgrade. It's a 1990 325i plastic bumpers. What should I be looking for if I want to get used OEM? Is Hella and/or Bosch the manufacturers? Is there a difference between US and euro ellipsoid fogs?
                      Thanks for the info, I just did a bunch of research on e30 headlights, but none on fog lights.
                      -Darius (aka DiscoDoughnuts on other forums)
                      dude man bro...
                      • 619E30
                        • 1753
                        I think those are euro fogs?
                        Originally posted by audiquattrot
                        bimmers b4 b*tches....remember that.
                        1990 Alpinweiss 325i - secret 500whp build
                        2000 Audi S4 B5 Laser Red
                        1990 Nissan 240sx - Drift Missile
                        2006 CBR600RR
                        • 619E30
                          • 1753
                          +1
                          I have same year and model
                          2006 CBR600RR
                          • straight6pwr
                            • Sep 2004
                            • 3450
                            Originally posted by 619E30
                            +1
                            unless someone can pipe in an say there are different fogs that BMW made at some point (i've never seen evidence of this), those ones posted are most likely the same ones you have on your late model cars, just cosmetically a little different.
                            • gearheadE30
                              • Jun 2007
                              • 3734
                              so far as I know, those never made it into production. All plastic-bumper OEM fogs are technically ellipsoid; look closely and you will see the glass lens. The OE lens is not round, and the cutoff is managed by shaping the glass rather than with a physical cutoff plate like that would have. Euro fogs are the same as U.S. fogs.
                              Project M42 Turbo
