Not too bad. Just installed Apexcone HID H1 4500 in my Smoked Euros. Also got original HELLA replacement lenses from German since mine were pitted and the passenger side was taking water. Made a nice custom wire install and was able to save all original plugs and wires from the Euro install. I just soldered a ground lead to the copper base connector inside the back of the bulb cap that the wires connect to. Also was able to drill thru the bulb cap and feed the harness to the ballasts. Used 3M sealant around gasket for wires to ballast and also around lens housing. All is Good EXCEPT the left low beam HID doesn't want to light up sometimes. I need to turn the lights on and off sometimes to get it to light up. Is this normal? Passenger side is rock solid..
Thanks
dlm ny
Thanks
dlm ny
