Noob question here on HID elip...
  • Heysüß
    • 911
    My right 5k HID elip is going off and on, i mess with the snap plug on the ballast and SOMETIMES that helps. Any ideas on how to fix this? this is my first e30 so please bear with me.
    09/1989 325i 4 Door
    +M30 Swap
    +Z3 Steering Rack
  • ak-
    • 12422
    Check all connection points.
    Unplug and replug, just keep messing with it.
    Check for bad wires.
    1991 325iS turbo
    • StereoInstaller1
      GAS
      • 22679
      If you didn't modify your wiring, you might wanna swap the stock bulb back in (yeah, I know, they suck) or swap components side to side to see where the issue is.
      Closing SOON!
      Thanks for 10 years of fun!
      • ck_taft325is
        • Sep 2007
        • 6880
        Best trouble shooting I've done with my HID's when a new ballast went tits up. Rules out the light etc.
        Are the US or Euro spec ellipsoids? Often times where the bulb itself sits can have some issues. Corrosion, bad contacts, not sealed properly, etc. Check side to side and then check the inside of the housing.
        Need a part? PM me.
        • Heysüß
          • 911
          i'll definitely give these a try. I'll finally be able to clean out the car this weekend. I've had test all week and I just got the car last saturday.
          09/1989 325i 4 Door
          +M30 Swap
          +Z3 Steering Rack
