Wiring question (correct me if I´m wrong)
  • Gadea
    • 454
    by looking at some diagrams and the actual wiring in the car, I matched these wires with their corresponding function. Some of the colors of the wires were slightly different than those referred in the diagram, so if someone knows this already, please correct me if I´m wrong or confirm I´m right. Before you ask, I can´t test it with the car itself because it´s not running.
    Left side tail light (please note the wires are numbered at the connectors)
    1 blue/red=turn signal
    2 green/brown=brake
    3 brown=ground
    4 blue/white=reverse
    5 gray/yellow=park
    6 empty
    Right side tail
    1 empty
    2 gray/white=park
    3 blue/white=reverse
    4 brown=ground
    5 red/green=brake
    6 blue/black=turn
    Windshield wiper wires
    harness side FUNCTION motor side
    brown=GROUND=brown
    red/black=SINGLE WIPE=white
    black/white=FAST=red
    yellow/black=SLOW=green
    thanks!
    1998 528i auto on staggered DSII
  • Gadea
    • 454
    I refuse to believe that we have so many geniuses e30-heads and no one can answer this relatively simple question. Someone please say "yes, you´re right" or "no, you got it all wrong"
    • Mo Brighta
      • 433
      Sounds absolutely correct on the tail lights, not sure on the wipers.
      That 'empty' spot on the connector? it's for the rear mounted fog lights, and on US spec cars represents a great opportunity for more, brighter and better tail, brake lights.
      PM me for more info.
      Andy
      Andy says "Be Seen, and Not Hurt!"
      Lighting Upgrades front and back for 2002, E3, E9, E10, E12, E21, E23, E24, E28, E30, E32, E36, E39, and more.
      Tail Light Improvements keep them off your tail.
      Headlight protection saves headlights from breakage.
