are RHD ellipsoids different?
  • e30sd
    Fistee
    • Jan 2004
    • 5517
    since they drive on the other side of the road. i mean is the cutoff to the left instead of the right?
  • e30sd
    Fistee
    • Jan 2004
    • 5517
    nevermind, i guess they're like this
    \__\__
    instead of this
    __/__/
    • E30ownerwithanopinion
      • 1526
      just mount them upside down.
      • e30sd
        Fistee
        • Jan 2004
        • 5517
        but then they'd be frownies :(
          • 1526
          yes since they were displaced from EUROOOOOOOOOOOpe they will be sad.
          • kencopperwheat
            King of Kegstands
            • 14396
            You can rotate all ellips to be either LHD or RHD.
            Originally posted by Gruelius
            • e30sd
              Fistee
              • Jan 2004
              • 5517
              how say you young man? rotate? do i actually swap the projectors side to side?
              • kencopperwheat
                King of Kegstands
                • 14396
                You see the three screws on the back of the part that holds the bulb and lens? Loosen them all and rotate the rear piece. It'll go from \_ to _/.
                • e30sd
                  Fistee
                  • Jan 2004
                  • 5517
                  do you speak from experience?
                  • Digitalwave
                    is a poseur
                    • 6284
                    Ken is definately one to experiment... if you know what I mean....
                    RISING EDGE
                    • kencopperwheat
                      King of Kegstands
                      • 14396
                      Yeah, I bought a set of euro ellips from the UK about a year ago and converted them to LHD ones. It takes like 5 minutes for both to switch.
                      • e30sd
                        Fistee
                        • Jan 2004
                        • 5517
                        thanks ken. your wisdom goes beyond what few years you've been around. i salute you youngster.
                        • Ryan Stewart
                          I Love Miatas
                          • 8978
                          You will need to undo the screws and pull the backs out a bit to rotate. There is a tab that goes into the front part of the lense that makes sure you dont align them wrong. as long as that tab finds the slot you are good.
                          Im now E30less.
                          • BavarianBimmer
                            • 951
                            That's the right way
                            I talk from experience, they're marked with L/G (Left/Gauche) and R/D (Right/Droite)
                            so it's LHD and RHD ,
                            1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
                            1997 E36 328iT
                            1990 E30 325iT 24v SOLD
                            1989 E30 325i 2.7i M-Technic II SOLD
