brake lights wont turn off
  • McGyver
    • 4634
    I changed the clutch master and slave cylinders and now the brake lights and fogs wont turn off. I've checked the fuses and they all appear to be good. I replaced the switch with one from a junk yard and it didn't help. I took the wires from the plug and touched them together and the lights still stayed on.
    I also installed rear fogs. They draw power from the aux fuse box, run to the euro switch, then to a relay in the trunk. From the relay power runs to the fogs. Power is also taken from the brake light circuit using a one way diode thing so the fogs come on when you hit the breaks.
    Where do i go from here to make them work properly again?
  • dave87325is
    • Aug 2007
    • 526
    its ayt.. then no one will be tailing u...
    u should change ur user name man...
    haha.. jk.
    best of luck with the problems. im sure somebody here will help you out unlike me. :D peace brah.
    weekend warrior!
    • McGyver
      • 4634
      i still have the problem and Bentley is as helpful as ^dave87325is.
      • McGyver
        • 4634
        turns out the bracket was bent away form the pedal so the switch wasn't pushed down enough.
