They leak water into them Every depo lense I have seen leaks and looks like shit with condensation or water inside the light. E30 Smilies, e36 angle eyes, e36 fogs, e36 smoked tails...
Ebay EURO ELLIPSOID SMILEY HEADLIGHTS
I've seen a set on a car personally, and the owner said they leaked water into the lense area from the day they were installed. He tried a few times to patch the seal with RTV, but in the end had to take them all the way apart and strip out the old silicone and start over. I haven't talked to the guy in ~3 months, but he had just finished doing the rebuild last time we talked.
Sounds like you better be prepared to take them all the way apart if you own these. Might give you a reason to do the M. Needler style smoke job, but only if you are comfortable ripping these things apart.
It's not how you handle the good times, but the faith you keep in the bad that defines you.Comment
That's a valid reason not to get them if they leak out of the box. :up:I've seen a set on a car personally, and the owner said they leaked water into the lense area from the day they were installed. He tried a few times to patch the seal with RTV, but in the end had to take them all the way apart and strip out the old silicone and start over. I haven't talked to the guy in ~3 months, but he had just finished doing the rebuild last time we talked.
Sounds like you better be prepared to take them all the way apart if you own these. Might give you a reason to do the M. Needler style smoke job, but only if you are comfortable ripping these things apart.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
I imagine that they ALL dont leak, but I have a set of cheapo ebay "euro"lights on my 1997 Chevy truck "ellips." the truth be told, the light pattern isnt aimed for crap, and the light output seems to get lost somewhere. let alone the plastic they are made from is absolutely the most brittle thin stuff in the world.Comment
wow, i wish i would have seen this thread earlier. i just bought these smiley's off ebay:
http://cgi.ebay.com/ebaymotors/BMW-E...QQcmdZViewItem
i'm guessing they're of the same poor quality as the ones referred to above. any opinions on this kind? i already bought them, so "don't buy them!" is kinda out of the question.
thanksComment
the worst part about them is the lighting quality. the cutoff on the lowbeams is terrible, and the high beam's focus is way off. and yes, lots of them end up leaking (mine did), and they are made of very cheap plastic.Comment
I just installed a set of the Depo smileys and did the preliminary aiming tonite. The patterns look fine to me with nice cut-off like they should on low beam. High beams will be aimed later. Since I live in AZ I'm not too concerned with the leakage issue.
The plastic actually looks fine to me, it's a heavy guage ABS or something similar, and doesn't look like it will be failing any time soon.
The only issue I had with them was the wiring hraness adapters the seller included with them, but nothing a little wire and shrink wrap couldn't fix in an hour.
I installed a separate circuit to run the lights with individual circuit breakers and heavy guage wire in case I want to run 80 or 100 watt bulbs(trying to run those through the headlight switch will probably melt the solder inside the switch, that happened to me years agon in my 240Z). The only concern I have is the plug in connectors for the H1 bulbs in the housing. I ordered some BMW connectors that I think I can modify to fit in there so we'll see...Comment
Do the depo's have the __/ __/ cutoff?
1992 BMW 325iC
1978 Chevrolet Monte Carlo1965 Chevrolet Corvair Monza 140hpComment
speaking of cutoff...my smoked ellips do this __X__ did I get some swapped lenses?
Every day I wake up we drink a lot of coffee and watch the CNN
Every day I wake up to a bowl of clover honey and let the locusts fly in.
Lobsterbacks attack the town again
Wrap all my things in aluminum
Beams of darkness streak across the sky
Pink rays from the ancient satellite
Every time I look out my window same three dogs looking back at me.
Every time I open my windows cranes fly in to terrorize me.Comment
1992 BMW 325iC
'89 325is S50 Track Montser
'04 X5 Daily/Tow Vehicle
http://www.avarestoration.com
http://www.myspace.com/brendanfiddle
Click here if you want to be my zombie slave...
http://www.youtube.com/user/Fidhle007
