its an 89 e30, and the lights only work when the doors are open. flicking the switch doesnt do diddily :(
interior light- works with door open, and nothing else
I got an interior light problem also. I'm watching this thread.88 M3 Diamantschwarz
89 M3 Zinnoberrot
56 Isetta
LIKE ARCHIE'S on Facebook!
Originally posted by dkbmxer002 View Postthe bulbs probably aren't making a contact with the other prong.88 M3 Diamantschwarz
89 M3 Zinnoberrot
56 Isetta
Check the wire under the rear seat. Betcha is worn through, mine was.88 M3 Diamantschwarz
89 M3 Zinnoberrot
56 Isetta
it's one of or more of a few things mentioned^^^^corroded contacts, prongs not making contact; bulb or contacts corroded, usually both. Since the light comes on with the door open, and not with the manual switch. I would suspect it is the prongs. However, the question remains do "both" sides react the same with the door shut? if it's one, then prob, the prongs. if it's both? then prob the wiring.sigpic
