Aiming Smileys?
  • BrooklynMW
    • 1263
    Aiming Smileys?
    I love my Euro Smileys, but I was wondering how adjustable they are. I'd love to be able to aim them better.
    I can see about 40-50 feet ahead of me, but if there are no other cars nearby, beyond that is COMPLETELY dark.
    Also, both sides seem to angle in the same direction. For someone like myself who is obsessed with symmetry, this is very unnerving.
    Sooo, anybody want to point me in the right direction for smiley aiming help?
    THANKS!
    Oh yeah one more thing. Are the low beams supposed to go off when you turn the high beams on?
    '87 325i "Chewey" (RIP, my beloved)
    current:
    '01 e46 325iT "Dot" - #datwagonlife
    '87 e30 325i "Tui" - she has her mother's eyes
  • Charley
    • 396
    How to adjust your headlights http://www.danielsternlighting.com/tech/aim/aim.html
    They are suposed to be angled in the same direction. Point is not to blind
    others and be able to see signs on the side of the road better.
    And I can't say for sure if the low beam are suposed to stay on or not when
    your high beams are on but on my car they do (my fogs stay on as well so
    my car as been modified thats why I can't say for sure)
    Charley
    • BrooklynMW
      • 1263
      Thanks, man. According to those diagrams, my headlights are properly aimed.
      That's all I needed to know. Now I can focus my hypochodriac brain on something else.
      current:
      • BMWManiac
        • Dec 2010
        • 1091
        My question is HOW do you adjust the light? Which tab makes the light go vertical? I need to lower my passenger headlamp a bit.
        1997 Artic Silver M3
        CES GT4094r 651hp/615tq @ 24 psi
        • reelizmpro
          • 9557
          First of all, make sure you have left hand drive cut off _/ vs right hand drive \_. If your lights came from the UK they are probably set to right hand drive. Secondly, go find yourself a large wall and park a good distance from it when you aim your lights. Get some lubricant on those adjusters so you can adjust them without stressing the plastic. It's easier when you can adjust them by hand. The bottom adjuster is up/down and top adjuster is left/right. You have to play with both to get the right positioning.
          88 M3 - LACHSSILBER
          89 M3 - ALPINEWEISS II
          • BMWManiac
            • Dec 2010
            • 1091
            Great info....would you happen to know which way to turn for up/down? The adjusters should be able to adjust by hand? If not, I will spray them down with some degreaser or the stuff used to soften bolts....
            • ZM Blue Devil
              • Dec 2006
              • 13836
              Remind me to slap you when you come back, you thought we would install them misaimed?
              Levent
              %20levent@gutenparts.com
              Ladies:
              • BMWManiac
                • Dec 2010
                • 1091
                Uh.....me?
                • BrooklynMW
                  • 1263
                  No, dingus. I'm just a hypochondriac.....you know that!
                  They were installed beautifully
                  current:
                  • BMWManiac
                    • Dec 2010
                    • 1091
                    I'm not sure if anyone else was aware of this, but I found adjusting the height to be VERY easy......in front, next to the lens, is a phillips head screw. Instead of trying to turn on the plastic part, just turn the screw.....I can't remember clockwise/counterclockwise, but it was extremely easy to raise and lower the light this way. A little PB blaster I'm sure loosen things up!
                    • reelizmpro
                      • 9557
                      That's another way to achieve the same thing. I don't like doing it this way because it's hard to judge how many revolutions you turned the screws, have to remove the grills, and you could break the plastic grommet that the ball sits in if you use too much pressure. It does adjust them a lot faster but it's harder to fine tune them this way in my opinion.
                      88 M3 - LACHSSILBER
