elipsoid wiring
  • armeN
    • May 2005
    • 327
    elipsoid wiring
    Hi. I'm buying some elipsoid headlights off my friend and I was wondering if I need his wiring too or can I just take the headlights and hook it up to mine?
    I go wuaaaaaahh pssssshhhhh!!!!
  • cramer
    • 1812
    you don't need the wiring, just the plugs. Make sure you have some length on the wire leads too. Cut and splice into your existing wiring and add the jumper to the headlight relay (so the low beam will stay on when the switching to the high beam).
    Chris
    90 Corrado/91 M3/01 M5
    • Hatchman
      • Mar 2005
      • 1425
      I've been wondering will h4 headlights need to be re wired or can they run off the exhisting wire and holder setup?
        • 34839
        AFAIK H4s plug right in.
          • 37833
          Ya my car has Hella H4 low's before I put the Euro ellips in and they just plugged in to the stock wiring
          Grover Beach, California
          BimmerHeads.com
          • Hatchman
            • Mar 2005
            • 1425
            thank you both :)
