so for about the past month, my passenger side low-beam would work intermittently. usually if it didnt work when i first started the car it would come on withing ten or fifteen minutes. then a couple of nights ago i went out to my car, turned on the lights, and the llow-beam flickered a couple times then went out.
it hasnt worked since.
this is a prolem, as i have already gotten pulled over once for it. no ticket though. i have 12v for both lights at the fuse box, but like .5v at the light. i swapped out the relay in the fuse box as well.
any other ideas? i visually looked at the wiring as close as i could, from the fuse box to the light. not much to see, its all wrapped up.
this is on a car converted to us ellipsoids and ddm hid's.
