Turn signal issue
  • moe30
    • Jun 2010
    • 721
    Turn signal issue
    So I am having an issue with my driver front turnsignal. About a month ago it stopped working, bought a new bulb and it was still dead.. So my next step was replacing the whole turn signal assembly... Still nothing.. So what should I look at next?
    Car hasn't been in an accident, all my other signals work. Any ideas?
    Oh this is on a 87 325 with DB's
  • immajackuup
    • Dec 2010
    • 1132
    fuse?
    mine work on and off because of loose wire.
    • bmwstephen
      • 2463
      relay?
      • moe30
        • Jun 2010
        • 721
        I thought about a relay but figured BMW wouldn't have a relay for each signal.
        On the fuse all of them were replaced when I bought it. It stopped working a couple months after I replaced them.
        • DaveSmed
          • Apr 2007
          • 1407
          Odds are that three pin connector on the back of the light housing itself dissolved a pin or two from corrosion. Have a look, just reach under the bumper and pull, there aren't any clips to squeeze or anything to release it. Does the connector look clean and healthy?
          -Dave
          2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
          Need some help figuring out the ETM?
          • moe30
            • Jun 2010
            • 721
            Just seeing this I'll have to look at it tonight after work
