How to wire your new Smileys
  • joeymc123
    • Jun 2011
    • 29
    alright i know ima n00b, i bought DEPOS, which people say are bad, but whatever im gonna try them myself. They look the exact same as the ones in the pictures up there^^. Anyways, How do i take off the cap on the back of the low beam and the high beam? do they screw off or just pull off?i just dont want to do anything and break anything And i see you drilled a hole in your cap, why is that. Is that only because you have HIDs? do you have to do that for HIDs? one more thing, each set(low and highbeam assembly) came with a little piece that i have no clue what it is. im gonna describe it as this: a long gold rod with threads, identical to the gold bolts that go from the black metal around the actual headlight through the bracket. On one end it has a littlke black cap thing that can swivel, the other end has a plastic bolt kinda thing thats white/cream, and in the middle is another bolt sort of thing, its black and has a little rubber gasket on it. WHAT IS THIS PIECE. please help im clueless :(
    • jaywood
      • Jul 2010
      • 4528
      The cap will unscrew, it's really tight though. Put some force into it. The hole in the back of the cap allows the bulb to fit with the wiring coming out of the backside (the HID kit from DDM has a suction cup type thing that will seal the hole up)
      Those rods might be the adjusters, pics would help.
      • joeymc123
        • Jun 2011
        • 29
        should i put the HIDs in before or after I install the lights on my car?
        • ethrtyiS
          • 8147
          after, installing hids require drilling into the cap. itll make it a lot easier if you did drilling and installed the bulb and all then installed it and hooked up everything once in.
          '89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5
          my feedback thread
          • jaywood
            • Jul 2010
            • 4528
            After.
            What are you going to do for the high beams?
            • joeymc123
              • Jun 2011
              • 29
              so i should put lights on the car, and then drill the holes and put the HIDs in??? that sounds weird... but im not gona put HIDs in the high beams, im just gonna keep normal bulbs cuz HIDs dont like to be flickered or something.
              • jaywood
                • Jul 2010
                • 4528
                I don't understand your question really.
                Do this: http://www.r3vlimited.com/board/show...&postcount=138
                Then do this: http://www.r3vlimited.com/board/show...&postcount=152
                How often do you flash your highs?
                • joeymc123
                  • Jun 2011
                  • 29
                  thanks, that helped ALOT. I flash my highs all the time, when I see someone I know, or something. So is it that bad to flicker HIDs? Either way I will be doing the relay jump so the lows and highs stay on together, but the only option is wether or not I put HIDs in the highbeams. I was thihnking of just putting in normal halogen bulbs, but the highest quality bulbs I can find so they are more white than normal. Would it look stupid with HID lows and non HID highs? or do you think I could pull it off?
                  • joeymc123
                    • Jun 2011
                    • 29
                    what I was asking before was, about the gold rod thing that I dunno what it is, Here in this picture is what im talking about
                    what is the thing in the bottom left, a gold rod with a white cap on the end. What do I do with that? I feel like I should know, please dont be mean :(
                    • joeymc123
                      • Jun 2011
                      • 29
                      Also, where did you get your HIDs from? and what color/temp are they?
                      • bernzpeed
                        • 3917
                        so is it the bulb that is 55w or the ballast?
                        89 E30 S52
                        Transaction Feedback.
                        • joeymc123
                          • Jun 2011
                          • 29
                          and whats the difference in wattage of the ballast/bulb. answer his question^^ then mine. thank you
                          • joeymc123
                            • Jun 2011
                            • 29
                            ONE MORE QUESTION I SWEAR. I feel like the suction cup lookin thing that seals thehole that you drill in the cap is crucial. So i dont want to buy a kit without that. Do all kits have that?? I found this kit for about 40 bucks, just want to OK this with you so I know this will be a good setup.http://cgi.ebay.com/ebaymotors/Xenon...mZ300412733308
                            If not, are these ones any better?
                            • ethrtyiS
                              • 8147
                              go with ddm. period.
                              my feedback thread
                              • jaywood
                                • Jul 2010
                                • 4528
                                That rod in the picture is one of the adjusters I think.
                                I have 5000k low beams and 6000k high beams. The HID kit I got was from DDM tuning. I got the raptor kit: http://www.ddmtuning.com/Products/Ap...Raptor-HID-Kit
                                The ballast is the 55w.
                                55w provides more light, here is a comparison picture (2004 m3 IIRC)
