No brake lights??
  • downforce22
    • Aug 2009
    • 3192
    No brake lights??
    I was told I do not have any brake lights. My brake light check light usually turns on until I hit the brakes and then goes out and would come on occasionally. I assumed that is what was happening recently until I was told my brake lights were out. I would go to the store and buy new bulbs but I do not think that is the problem.
    I checked fuse 6 and it is fine. I switched the bulbs and that did nothing. The thing that leads me to believe it is not a bulb problem is that the third brake light is out as well.
    Any ideas?
  • HighschoolE30
    • Jul 2011
    • 83
    Bump
    My 318is is pulling the same BS....
    • TimKninja
      • 2131
      Check the switch itself, ended up being the problem on my car. it was seized. so the brake lights wouldnt come on, and would illuminate the check light.
      1985 325e M50TU(Sold)
      1991 318is Slicktop (Sold)
      1990 325is Brilliantrot S50/5 Lug Swapped.
      1992 525i Manual shitbox Winter Beater
      • mr ilia
        • May 2011
        • 582
        Yes, chech the brake switch, it is located at the brake pedal assembley. 10 min job to change it.
        Mine was faulty as well (no lights)...I had to take it appart and clean it...works for now. I have spare, just in case.
        • blefevre
          • Dec 2008
          • 4287
          Yep, brake switch. I cleaned mine and it worked for a few months until gave up again. My new one has been working just fine after that.
          - E30, DSM, Golf R, Mazda 3 Skyactiv
