My rear lights work great on the drivers side of the car but the passenger side tail light will trigger the brake light instead of the turn signal. Hitting the brakes causes the turn signal indicator to light up slightly. If i have the turn signal on it will blink when to the right unless I hit the brake and it will stay solid dimly lit.
Turn signal triggers brake light
The ground on that side is bad.-Dave
2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
Need some help figuring out the ETM?
