rear license plate light dont work
  • McGyver
    • 4635
    I checked all the fuses, made sure the headlight switch was pulled all the way out, checked the bulbs with a meter thing and they're good, and checked for voltage across the positive and negative terminals for the bulbs. I dont have any voltage for the bulbs. Also, every other exterior light looks like its working properly.
    Where should i check next? the check relay?
  • McGyver
    • 4635
    also, my car seems to be eating a World Wide alternator every year if that helps anything.
    • Doughnut
      • Oct 2007
      • 869
      Pull the carpet from inside the boot and check wiring, that is where I'd go after doing all the things you have already done.
      ///Monstrosity. (OO≡≡[][]≡≡OO)
      Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
      • dogsbark26
        • Nov 2008
        • 533
        Check continuity from the rear license plate light harness connections the short distance to the light bulb spring clips. You can do this with the fixture removed from the vehicle. Mine needed solder near the wire harness connectors to get power to the lamp. My wires were not the problem.
