Looking for full Foglight system Retrofit DIY
  • SSE30
    • 362
    I am searching for a foglight system retrofit DIY to install fogs into my 318is. Would this be a fairly easy project?
    I have searched but have had no luck finding a DIY thread.
    Thanks.
    1991 318iS Sterlingsilber - 1989 325i Cirrusblau (sold) - 1990 318iC Brilliantrot (sold)
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    If you have a 318is, then you should already have foglights. If you don't have the actual foglights, then you definitely have the wiring in place for the foglights and all you need to do is buy a pair and install them. Don't forget to buy the hardware.
    It's on realoem.com
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
    • SSE30
      • 362
      It's on realoem.com
      Thanks so much man, didn't even consider that the PO just took them out.
      Appreciate the info.
      • Woofer
        • Aug 2005
        • 82
        ^^ he's right AND IMO only the factory fogs look good. Anything else seems out of place. Just my 2 cents.
        GL
        • McGyver
          • 4637
          it may not have been the PO, every car i've seen has had the wireing, but some just get the fog light deletes instead of the fogs.
          • SSE30
            • 362
            What does the connector look like? Where is it hidden?
