Side marker removal for euro trim: HELP WITH RESISTOR SPECS?
  • GermanEngineering
    • Oct 2009
    • 51
    Hi I am installing euro trim on my 1990 e30, I think the bulbs are 5watt w5w, I don't know a lot about electrical stuff but I do know I need a resistor, can anyone tell me what kind I need and the cheapest place to get them?
    -Thank you very much
  • DaveSmed
    • Apr 2007
    • 1407
    You do not need a resistor. Just tuck the wiring up out of the way in a safe place.
    -Dave
    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
    Need some help figuring out the ETM?
    • blazinxpk
      • 839
      I believe DaveSmed is correct, i had my sidemarker connectors tucked away with my euro trim and everything work fine.
      now somewhere a resistor can be used is when you use led bulbs instead of the standard ones. this is a solution to the "hyper blink" but is only needed sometimes.
      • jaywood
        • Jul 2010
        • 4528
        I didn't use any resistor either. Just unplugged the sidemarkers and hid the wiring/plug.
        • GermanEngineering
          • Oct 2009
          • 51
          Thanks guys, I think since they are only 5w, the system does not notice.
          • AndrewBird
            The Mad Scientist
            • 11898
            It has noting to do with the "system not noticing". It's just a bulb, if you unhook it, it's like it was never there in the first place.
            Maybe you are getting them confused with turn signals? If you are missing a turn signal bulb, the flasher with blink faster due to a lower load on the system, but since the side markers don't flash, this isn't a problem.
