headlights only come on when turn the high beams on...
  • ELIXIR
    • Mar 2012
    • 252
    hey before i waste time diagnosing the headlight system I figured i'd throw a post up. Whats the most common issue for this? Low beam bulbs turn on when i flip the high beams on. High beams dont work at all.
    is this a wiring, relay, or stalk/switch issue?
    thanks
  • jaywood
    • Jul 2010
    • 4528
    What headlights do you have? Are you sure the low beams are turning on, or is it just the highs?
    • xphiledan
      • 706
      i had the same problem. check the relays.
      • jrobie79
        • Mar 2006
        • 2526
        low beams are dual filament
        1991 318i ---- 308K - retired
        • bmwguy325is
          • May 2011
          • 1263
          Before checking the relays are you still rockin the sealed beams? As said the sealed beams are dual filimant it could be that your lows died at the same time. I have seen it before.
          sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
          The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
          • ELIXIR
            • Mar 2012
            • 252
            yeah I have the sealed beams still installed going to be swapping my elips soon as i get the hids from dtm. doesnt bother me really... just have to flip the switch as long as I have lights im ok! :)
