Moving from sealed beams to Smileys. How do I make this change?
  • e30forlife
    • Mar 2012
    • 583
    What do I need to make this change. Just bought some smileys off here and was wondering what do I need to convert my old sealed beam look to these smileys?
    91 318 s52 Swap
    -m50 manifold
    -headers
    -zf320
    -3.25lsd
    -KaMotors Intake
  • jrobie79
    • Mar 2006
    • 2526
    there are several writeups floating around here in the DIY and on google as well
    1991 318i ---- 308K - retired
    • blazinxpk
      • 839
      sealed beams with have a three wire plug. you will only be using two wires from that plug, all you have to do is find which wire is power and which one is ground. that is basically the hardest part. the installation is pretty straight forward. you with either have to get euro connectors or jerry rig your own if you dont have them already.
      the easiest way to setup the city lights is to splice into your sidemarker wiring and connect that to the city lights. so that whenever you have the parking lights on the city lights will be on as well.
      if you use hids, then you can eliminate the connector and crimp the wires together using appropriate methods.
      one more thing: the connector for the city lights is the same as the late model fogs.
      i think thats basically it. just remember to take take precautions and never connect two random wires together.
      here is a list of bulbs just incase you need it:
