No low beams
  • E30Strube
    • Jul 2008
    • 181
    No low beams
    I'm finishing up my swap, but I now have no low beams. I have a 90 M3, so it came with the standard halogen lights. I have since changed to ellipsoids. I have continuity in the wiring from fuse box to light. There is no power at fuse 13 or 14. For the relay, I only have power at pin 85. Should pin 86 have power all the time or when the lights are turned on? Even when I turn the lights on, no other pin has power. My brights work, as do the inside the cabin lights.
    What should I be checking?
  • bmwguy325is
    • May 2011
    • 1263
    Do all four lights come on when your highs are on?
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    • E30Strube
      • Jul 2008
      • 181
      I never put the extra relay in when converting to the ellipsoids, so only the highs came on before. Same now. Basically, I should have no link between highs and lows.
      • bmwguy325is
        • May 2011
        • 1263
        Did you get euro lights or USD elisp lights?
        • E30Strube
          • Jul 2008
          • 181
          Euro smoked hellas. Everything worked before the swap, but now they don't. I didn't do anything to the lighting wiring though, so its kind of weird. Especially since all other lights work fine.
          • bmwguy325is
            • May 2011
            • 1263
            Find DYI on sealed to euros. There are some wires you have to swap and a relay you have to jumper.
