Low beam out, question?
  • ME30W
    • Feb 2012
    • 811
    My left low beam went out today and while the fuse didn't look blown I decided to change it anyway just to start the troubleshooting.
    That did not work, and there doesn't seem to be any loose wires, and I haven't touched them since I bought the car a few weeks ago.
    I'm thinking it is simply a burnt out bulb, but I'm not 100% sure as the "CHECK" light is indicating that I have a low beam out. I was under the impression the "CHECK" light would only go off if a fuse was blown, but obviously that is not true.
    Other than a burnt bulb, does anyone have any ideas as to what else it could be?
    Thanks
    I like cats.
  • stamar
    • Apr 2011
    • 1362
    It is a burnt out bulb.
    • Vivek
      attention whore/retard/bitch
      • 6167
      I'm 99% sure your bulb burnt out. It happens all the time.
      1992 Mauritiusblau Vert
      2011 Alpinweiss 335is coupe
      2002 540i/6 Black/Black
      2003 GSX-R 750 (RIP)
      • DaveSmed
        • Apr 2007
        • 1407
        The beauty of the active check control system is it monitors actual current flow, so any failure (including an open filament in a bad bulb) will be detected.
        -Dave
        2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
        Need some help figuring out the ETM?
