E30 Fog Light Mod?
  • RemSteele
    • Nov 2005
    • 14
    E30 Fog Light Mod?
    Can anyone tell me if this is a easy mod. Also my E30 is my weekend car (X5 3.0i during the week). After sitting for the week when I turn on my radio, sometimes I get a "hit pitch sqeal". After a 15-20 minutes it seems to play itself out. Does anyone have any ideas (amp maybe). I 've had the radio out and checked out, Was told it was fine.
    Thanks,
  • Avus E30
    • 3650
    what do you mean by "fog light mod" Radio I cant help ya on but as long as it goes away after a while driving I wouldnt worry too much.
    HDE30 <3
    • DoriftuEvo
      • 236
      That's what happens to the original stereos. I can't turn my volume down, I have to turn it off and then turn it to a lower setting. A friend's original unit crackles terribly when adjusting the volume. I'm no audiophile, but I'd guess a new headunit would fix it.
      I'm also interested to find out what this fog light mod is.
      • erik325i
        • Jan 2005
        • 3567
        What exactly do you want to mod with your fog lights?
        • robert325is
          • Aug 2004
          • 1171
          probably wants to run independent fogs.
          all you do is jump the relay w/ a piece of wire.
          • e9nine
            • 1890
            Use this for the fogs: http://e30.bmwdiy.info/indy-fogs/index.html
            I don't understand what you're trying to say about the radio. Elaborate a little bit more so other's can help you out as well (unless I am the only one who doesn't comprehend your post)
            • Rob
              • 8166
              I've had my fogs "wired" independent with a little bit of aluminum foil for over 3 years. FWIW
              BEERTECH
              • Hawk
                • 549
                Will that work on an 88' car?
                Summer '85 E24 635csi Winter '88 E30 325iX, I lose 25% of my hp before I even turn the key.
                • S14sx2nr
                  • Mar 2004
                  • 436
                  yup.
                  -Dan
                  never enough money...
                  '95 240sx base - RB25DET in progress
                  '87 325ic - Project daily
                  • RemSteele
                    • Nov 2005
                    • 14
                    Wow. Thanks. Sorry I have not replied, I was just checking the "thread" and it read "0" so I didn't think anyone responded.
                    Yes what I was looking for was a way to run my driving lights with my parking lights only. The "dyi" website was perfect but I must admit I'm concern that the relay dosen't seat totally.
                    Yes The radio also "crackle" sometimes not to be confuse with static when turning up the volume. That can be taken care of with spray. Don't spend $150 like I did the first time. But my E30 is all org. except for the glovebox mounted changer. I will replace the amp if I have to.
                    Again thanks,
                    RJ
                    • parkerbink
                      • Jun 2004
                      • 10138
                      I have an oem Blaupunkt amp that worked perfectly 10 or so years ago when it was no longer used due to the orig. head unit coming out.
                      • RemSteele
                        • Nov 2005
                        • 14
                        Is that the type BMW used? I haven't taken it out but I thinks it is mounted in trunk on the left side.
                        RJ
