anyone try led headlights yet?
  • stamar
    • Apr 2011
    • 1362
    came across these when looking for rv dome lights
    seems cheap, would use less power than hids and could be much brighter if it wanted to.
    I had been under the impression before that it was expensive but it seems cheap as can be.
    I havent tried these but thatd be cool if someone could review them.
  • AndrewBird
    The Mad Scientist
    • 11898
    Those would likely be no where NEAR bright enough to use as headlights. Note how it says it's a fog light bulb. Even as fog lights, they would likely be dimmer then standard bulbs. You need multiple 3-watt LED's per housing to reach incandescent levels of light. This bulb is only 5.5 watts.
    • stamar
      • Apr 2011
      • 1362
      gotcha
      what is the number were looking for for a headlight bulb?
      Im actually doing this project for my rv, as all power saved is going into deep cycle power.
      for my bmw it seems less important because all power saved.... is just wasted.
      I want some led headlights for my toyota truck more.
      • nrubenstein
        • 3148
        There is no such thing as a cheap LED headlight. Forget about it.
        2002 BMW M3 Alpinweiß/Black
        1999 323i GTS2 Alpinweiß
        1995 M3 Dakargelb/Black
        - S50B32/S6S420G/3.91
        1990 325is Brilliantrot/Tan
        1989 M3 Alpinweiß/Black
        • stamar
          • Apr 2011
          • 1362
          these ones say they are for headlights.
          • nrubenstein
            • 3148
            Originally posted by stamar
            http://www.ebay.com/itm/2X-Car-9006-...ht_3416wt_1129
            I stand by my statement.
            • ACS Cabrio
              • Aug 2012
              • 243
              if you buy a cheap led plug in bulb, it will look like you have bright running lights installed
              • mr ilia
                • May 2011
                • 582
                LED bulbs do not produce enough lumens for acceptabale illumination.
                • nrubenstein
                  • 3148
                  At least not in a form factor that will fit into a standard housing.
                  LED headlights are great when they are purpose built.
                  • bmw325csi
                    • May 2007
                    • 4045
                    can these be used to act as daytime running lights in the high beams.
                    I plan on installing bi-xenon in the lows in the winter.
                    harry/harout
                    • nrubenstein
                      • 3148
                      Sure. Although you would have to modify them a little to work in a 9005 base.
                      • Skunkworks
                        • Sep 2012
                        • 436
                        we use LEDs in our offroad trucks, you will be spending $500+ to get a safe headlight set. wait a couple years..
                        • stamar
                          • Apr 2011
                          • 1362
                          ya actually for my real purpose, the toy truck its not even available.
                          an led bi h4 type thing doesnt exist with brights.
                          For what bmw 325csi suggested thats what the ones i listed are for.
                          • stamar
                            • Apr 2011
                            • 1362
                            If you dont have a use for saving alternator power it is less relevant.
                            but in an rv its like free money.
                            for an older car there are uses you can engineer for extra electricity.
                            But the smartest would be to somehow downgrade the alternator and get more hp.
                            once those headlights are gone, the alternator can be a fraction of its size.
                            • Holland
                              • Nov 2008
                              • 7178
                              UUC has an LED headlamp for the E30. Super expensive and ugly.
                              Originally posted by DEV0 E30
