LED taillights
    • 34839
    #106
    Originally posted by DaveSmed
    The best chance of something usable from that site would be the board with the Luxeon LEDs set back as far as possible with the reflector cut off the back of the taillight, and a recess made in the removable light panel to get it as close to flush as possible.
    It must be the Luxeons, the cheap ones will NOT work right. The Luxeons might. You'll notice there also the most expensive. There is a very good reason for that.
    Personally, for the expense, possibility of failure, and amount of work needed to get it in there, what the hell is so wrong with a bulb that works pretty damn well? If there was some amazing benefit, sure, but what? You dont like replacing $2 lightbulbs roughly once a year?
    once a year? in 6 years/75k I've only replaced one.
    basically, it's just for looks.. and after you have the same car for a while, it gets boring. :p
    • 84E30
      • 456
      #107
      hey guys where can i pick up some of
      those led lights for the back
      n signal lights?
      hit me up ppl
      Check out my Insurance Thread
      http://www.r3vlimited.com/board/showthread.php?t=164190
      • Inspar8r
        • 301
        #108
        Because most people don't like the "dot" of light coming from the middle of replacement bulbs.
        That said, like I've posted before, I'm not here to convince anyone. My work speaks for itself, as will thousands of other customers who have purchased my products.
        I build things that suck, so if in the end, they end up sucking, you'll simply see a post saying it didn't go as planned. Luxeons are an option, but at this point, it's not necessary.
        For those who want LED tails, great. For those who don't, great. People will want them because they are rare, they give you 15ft of additional reaction time @60 mph. But most of all, because they are cool.
        By your logic no one should mod their car because the car already does it's intended function.
        Nick
        87 325 5MT
        02 IS300 5MT
        • Inspar8r
          • 301
          #109
          as for an update, I haven't made much progress, I've been slacking off, and I have a ton of web orders to fulfill for the IS300.
          I'm hoping chris will be able to help out on sunday, perhaps get the additional boards built and start testing them out. I had to change a load resistor for the front turn signals because I had to account for 14.4V dynamic power (it's 13.7 believe it or not on the IS300).
          Nick
          87 325 5MT
          02 IS300 5MT
          • sweetride01
            • Apr 2004
            • 713
            #110
            So the fronts are almost done?
            That would be sweet! If you had some Euro smiley parking light LEDs running off the side light power, would it affect the turn signal functioning? I doubt it, but always better to ask...
            Moving sale: Everything Must Go!
            FS: 2001 740iL Sport, low mileage..... SOLD
            FS: 1990 Mtec II 325iS, $12,0K OVNO
            FS: 2003 Honda Odyssey EX-L Navi..... SOLD
            FS: New Rieger lip, lachsilber metallic (WILL INCLUDE W/e30!!)
            FS: Very rare, new lachsilber metallic E30 Aero pack sideskirts... (WILL INCLUDE W/e30!!)
            Extreme 325iS (well, slowly getting there, anyway)......
            Almost too many mods to list ;-)
            • DaveSmed
              • Apr 2007
              • 1407
              #111
              Yea, thats what I'm referring to with LED replacement bulbs. Your LED panel design eliminates that and is the "right" way to go about having LED taillights. Too many people are interested in the cheap or easy way, not necessarily the right way. I cant help but laugh at the cars with a dimly glowing spot the size of a quarter in an otherwise dark taillight who bought LED "conversion" bulbs thinking they would get a visibility improvement.
              To realize the benefits LEDs have, proper design must take place. Sounds exactly like what you are up to, much appreciation for that.
              Load resistor... are you talking about modifying the flasher unit itself, or adding a dummy resistor? I understand a plug and play system is more desirable, but I would think a different flasher would be a good choice to realize the benefit of lower current draw.
              -Dave
              2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
              Need some help figuring out the ETM?
              • Inspar8r
                • 301
                #112
                Changing the flasher has had spotty results in other applications, so I will use a resistor that will maintain the correct flasher rate. They won't ever get hot for the turn signals, because the voltage is not constant.
                Perhaps this weekend chris and I can test out the front LEDs again.
                Nick
                87 325 5MT
                02 IS300 5MT
                • sweetride01
                  • Apr 2004
                  • 713
                  #113
                  Any news???
                  Someone else on here already did their own custom setup that's pretty sweet, I want to know when your stuff is done ;-)
                  • VAPORBLADE
                    • Sep 2006
                    • 1771
                    #114
                    if I remember Libertek does some nice custom work in canada. They did my old CBR.
                    '89 "is" = M technic II build mode.
                    • Sam Cogley
                      • Jun 2008
                      • 521
                      #115
                      I have the LED conversions in my 77 Corvette - they light up the stock taillight lenses as well as stock replacement incandescent bulbs and are brighter. YMMV.
                      • MaxBell
                        • 1391
                        #116
                        I hate to dig something up from everyone's past, but what came of ye olde LED taillights?
                        REMEMBER: Be safe and have fun is Rule Number 1.
                        The Epic Unbuild of Clint Eastwood
                        • george graves
                          • 20003
                          #117
                          Outside of the average r3v'ers budget.
                          Originally posted by Matt-B
                          • sweetride01
                            • Apr 2004
                            • 713
                            #118
                            I woulda bought them... but then I'm selling my car now, so a bit pointless...
                            • george graves
                              • 20003
                              #119
                              The thing about something like this is that you'll get people saying "I'd buy them! I'd buy them!" but then when he offered to custom make them it was all crickets....
                                • 34839
                                #120
                                they would buy them - for $10 a pair, you pay shipping. ;)
