Foglight aiming
  • MJTSUB
    • Aug 2004
    • 42
    Foglight aiming
    Is there anyway to aim the foglights. I have one foglight on that is doing a nice job of lighting up the tree branches above me. I have and 89 325iX with plastic bumpers. Thanks for your help.
    • 37833
    There's 2 adjusters on the front of each fog light. Pop off the little rubber caps. One adjusts left to right and one is up and down
    Grover Beach, California
    BimmerHeads.com
    • MJTSUB
      • Aug 2004
      • 42
      Nice thanks. Do these rubber pieces just pry off?
      • Avus E30
        • 3650
        Yeah just use a small flat screw driver and go slowely and they pop right off.
        HDE30 <3
        • demlotcrew
          • May 2004
          • 297
          Is this on later cars?
          Andrew
          Andrew AT E30zone.co.uk | H23-is | S14
          • parkerbink
            • Jun 2004
            • 10138
            Andrew
            Yes.
            • demlotcrew
              • May 2004
              • 297
              Im sure that the later fog can only be adjusted for vertical aim not horizontal. As the Centre screw is what holts the lamp to the bracket and the top one adjusts the aim.
              Not sure if the US cars are different.
              Andrew
              • e9nine
                • 1890
                Andrew
                ....AFAIK you're correct. The top screw is aim up & down adjustment and the bottom screw attaches it to the frame, unless these guys have seen a different version of fog lights yet to be seen by us?
                • cheffy30
                  • Sep 2016
                  • 1159
                  i am at a loss...
                  i installed new out of the box fogson my 1990 e30 325i sedan. upon inspection all is good. the adjusting screws on both were at the same position...
                  upon installation the drivers side lights up the fog line perfectly. the passenger side is up and to the right about 45 degrees...
                  i have tried everything i think to get them to aim correctly... moving the screws etc...
                  the front valance is true and not bent or dinged...
                  any other mcgiver suggestions to get them to move??
                  any suggestions appreciated.
                  thanks
                  '90 325i sedan daily driven
                  '85 325e coupe also a daily
                  • ELVA164
                    • 4861
                    Originally posted by chefpeterlevine
                    i am at a loss...
                    thanks
                    Pictures would be helpful. The adjustment screw isn't working?
                    • dlmrun2002
                      • Apr 2007
                      • 808
                      Perhaps your valence is bent????.
                      dlm ny country
                      • Mo Brighta
                        • 433
                        Fog light out of whack
                        If the mounting bracket is good, and the light face matches the valance and points similarly to (symmetric with) the driver side, then I'd check the lamp in the reflector. A small misalignment of the filament can throw the beam way out, even millimeters can be fatal.
                        Try swapping lamps from side to side, see if the crazy angle goes with the lamp. Normally the filament location in relation to the base flange is within less than 1 mm; sometimes a bad one slips through. Or maybe it wasn't fully seated in the opening - it's been known to happen.
                        Good luck, let us know what you find and if/how you resolve it.
                        Andy says "Be Seen, and Not Hurt!"
                        Lighting Upgrades front and back for 2002, E3, E9, E10, E12, E21, E23, E24, E28, E30, E32, E36, E39, and more.
                        Tail Light Improvements keep them off your tail.
                        Headlight protection saves headlights from breakage.
                        • othatseric
                          • Jul 2016
                          • 199
                          Not to hi-jack the thread, but does anyone have any pointers on how to properly aim the foglights?
