Upgrading from sealed beams
  • freeride53
    • 11972
    Hi guys. I briefly mentioned this on my project thread, but I am looking to upgrade from the fogged-up and burnt-out sealed beams on my 1991 318i.
    Granted one of the low's is burnt out, and the rest have started to accumulate condensation, the light output over the past 4 years of me driving it was just far too low, and annoying when driving the 101 frequently in the dark (no illumination on highway for many many miles).
    So right now, I'm looking to upgrade, but with affordability in mind.
    I'm currently considering the chrome eBay DEPO smileys, and I've heard about doing the h1/h4 conversion, which also sounds tempting.
    I don't want to do something too expensive, or something that would be inconvenient to install.
    The thought of DEPO smiley sounds good because from what i've heard, installation from sealed beam is somewhat plug-and-play.
    I currently have h3 35W 2000K HIDs as my fogs, and it's sorta pathetic to think that my fogs give better illumination than my headlights.
    Untitled by sina.pour, on Flickr
    Whatever setup I run, I'm thinking of having amber lows.
    I would appreciate some feedback and suggestions, as I am not too experienced when it comes to auto lighting.
    Thanks!
    1983 Peugeot 505 STI
    1992 Volvo 240 Wagon
  • blazinxpk
    • 839
    the bottom line here is that anything is an improvement from sealed beams.
    my suggestion would be to get some type of projectors, so that you have the best possible cutoff. pair that with some hids and youre done.
    honestly get whatever you can afford in terms of depo, Euro/US ellips. just make sure the lights are in good condition and everything works.
    in terms of what bulbs to get. i would recommend an hid kit(of your choice, based on money) with a bulb temperature of ~4300k. 4300k bulbs provide the maximum light output.
    i dont understand your comment about wanting amber lows. amber is the color of turn signals and that would be a stupid color for your low beams. i dont think ive even seen amber low beams before. also a suggestion about your fog lights, i would consider 2000k "all show no go". if you were to just change those bulbs to either 4300k or even 3000k your light output would be better.
    this is all i can think of right now...
    • freeride53
      • 11972
      Wait, you've never seen amber headlights before?
      Bro take a little trip to france. By the way, it's a little different than the turn signals.
      almost every single e30 in france has ambers.
      also, the amber fogs work phenomenally in fog.
      there is a lot of fog where i live.
      • blazinxpk
        • 839
        thats not amber.
        if you are so concerned with fog you should change the 2000k bulbs you have in your fogs.
        • JasonC
          Site Manager
          • 14451
          3000k HIDs = yellow.
          But with the DEPOs they may leak so you might want to reseal them. Also if you go with the used US ellips. remember they are 20yo used headlights now so the chrome reflective suffice in them might not be up to par and light output will suck.
          1992 BMW 325iC
          1978 Chevrolet Monte Carlo
          • freeride53
            • 11972
            Originally posted by blazinxpk
            thats not amber.
            excuse me, "french" yellow.
            • Alex Mc
              • 281
              I recently installed the DEPO smileys on my '91 318is and couldn't be happier. There are many people who will decry the Taiwanese replicas as garbage and unworthy, but the fact of the matter is that they are new ellipsoid projectors for $125 shipped. The look identical to the real ones. And I do speak from experience as I had Hella smoked smileys on my M3 - I promise you there is not much difference after they're installed, but you do have to be gentle as the plastic frames aren't as hefty as the Hella/Bosch pieces. If the DEPOs collect moisture - fine, reseal or vent them. No big deal. They work great and I'd recommend them.
              I will say that if I was updating a nice, low-mileage E30 M3 then I would spring for factory parts, but why would I buy a set of headlights that are worth 10% the market value of my car?
              Current: Brilliantrot '91 318is M20B25
              Former: '88 M3 3.2L, '91 318is 2.0L, '90 318i, '85 325e 2.8L, '84 318i 2.0L, '84 318i, '90 325is
              wamchenry@gmail.com
              insta: @simple_machines
              • jeffnhiscars
                • Jun 2011
                • 6010
                Originally posted by Alex Mc
                ...but why would I buy a set of headlights that are worth 10% the market value of my car?
                For the same reason we spend 20% on shocks/springs, 15% on tires & crazy amounts on sound..because we can ;)
                Alice the Time Capsule
                • Mo Brighta
                  • 431
                  Headlight upgrade
                  i dont understand your comment about wanting amber lows. amber is the color of turn signals ...
                  Ditto on sealed beams, they are not useful.
                  Amber is the color for turns, but yellow is common for headlights. May be a fine distinction, but still, you might want to consider yellow tinted headlight film ($12 a pair, perfect size for 146mm (5-3/4") lights. If you don' like the color, you can apply two for more, or peel it off and be back to clear. Any color will reduce output, and my experience on the 101, you need more rather than less light- lows are in use most of the time. The majority of cars that I see with yellow headlights are highs, not lows.
                  BMW did a really good headlight design with Hella back in the 80's for the e30, it's called the BiFocal, and it is fantastic. It's a low beam, ALL low beam. It uses an H1 bulb, it's metal, and has a city light option if you like that sort of thing. Made for the Euro market, they never made it over here until now.
                  They are around $96 each, but boy do they make light! If you can afford them, you can play with bulbs and film to make them as bright and /or as yellow as you like, do you know if there's an HID for H1 lights???
                  Let me know if you want pics or technical data on them, I have these available on short notice if you want.
                  There are several good and relatively cheap High beam options, I like the Cibie flat face H1 highs, also available on short notice.
                  BTW, that's a French Yellow Cibie CSR in my profile pic, sorry, they are NLA.
                  Andy says "Be Seen, and Not Hurt!"
                  Lighting Upgrades front and back for 2002, E3, E9, E10, E12, E21, E23, E24, E28, E30, E32, E36, E39, and more.
                  Tail Light Improvements keep them off your tail.
                  Headlight protection saves headlights from breakage.
                  • jaywood
                    • Jul 2010
                    • 4528
                    Depo smilies (I have the smoked version) with DDM tuning 55w ballasts and bulbs. 5000k low, 6000k high. Both 55w. They work excellent. They light up the road extremely well and haven't given me any issues in the almost 2 years that I've had them. I also jumped a relay so the highs and lows stay on at the same time. It was a VERY simple installation.
                    Old stuff out (had sealed beams too)
                    New headlights in
                    HID kit:
                    Take the black/blue wire out of the suction cup thing and seal up the holes
                    Hook up the ballast like this:
                    Drill a hole in the headlight cap (1 inch)
                    Put bulb in
                    Take apart the sealed beam connector: (you don't need to do this, you can use Something Like This and plugs into the stock sealed beam connector.)
                    Figure out which wire is power and which is ground (brown). There should be three wires (low beam). One is the power, one is ground, and the other you won't be needing.
                    Hook up the black wire to ground and the blue wire to the power wire
                    Hook up the rest of the headlight/ballast
                    The other wire (blue/white) is the one you won't be needing...go ahead and use a wire nut on the end of it for protection
                    Both low beams on
                    For the high beams I'm running the same HID kit. The wiring is the same procedure (the only difference is that there will only be 2 wires that plugged into the original sealed beam....one is ground, brown, and the other is power)
                    I also jumped the relay (#30) so that I could run the high beam and the low beam at the same time
                    Adjusting the cutoff:
                    All done and cleaned up
                    • bmwguy325is
                      • May 2011
                      • 1263
                      Ya go HID cause they are legit...................
                      Plus then you can help feed a kid in China as sweat shops pay good.
                      sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                      The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                      • jaywood
                        • Jul 2010
                        • 4528
                        Politics and Religion
                        Just posting from personal experience. MANY others have HID's as well (for 5+ years) and have no complaints. Never have I been "flashed." I don't see what the problem is. They are a great improvement over stock that don't require a ton of work.
                        • ELVA164
                          • 4861
                          WAIT. I really hope you haven't done anything yet because I really want to see someone try these.
                          HIR bulbs. Supposed to be the nest best thing to the best HID's and you literally don't need to do anything except buy them and put them in your existing 9005 and 9006 sockets. Please try it.
                          This website is for sale! hirheadlights.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, hirheadlights.com has it all. We hope you find what you are searching for!
                          • blazinxpk
                            • 839
                            • bmwguy325is
                              • May 2011
                              • 1263
                              Originally posted by ELVA164
                              WAIT. I really hope you haven't done anything yet because I really want to see someone try these.....
                              http://www.hirheadlights.com/
                              Seems legit...
