HID Ballast Mounting
  • royalflush313
    • Mar 2004
    • 2070
    Those with HID kits (esp. those with a separate igniter), where exactly did you mount your ballasts?
    For now, I used heavy duty velcro to keep the ballasts in place, but they are sitting outside of the plastic cover. Ideally, I want them out of the view, inside the cover, so another option is to use zip ties, but that's even more ghetto than velcro
    ~ Go Canucks Go! ~
  • e30sd
    Fistee
    • Jan 2004
    • 5517
    the xtec kit came with this crazy double stick adhesive, works better than the velcro i've used in other installs. the ballasts also had several loops for zip ties. whatever you do, just make sure it's secure; if it shakes around it's more prone to failure.
    • royalflush313
      • Mar 2004
      • 2070
      ^^ Thanks. Didn't know about the shaking -> failure thing. Maybe I should use bolts to mount them.
      Well either way, method of mouting isnt a huge issue, if I find a good location, I can figure something out.
      Where exactly did you mount yours?
      ~ Go Canucks Go! ~
      • e30sd
        Fistee
        • Jan 2004
        • 5517
        i mounted the driver side one near the shock tower, and the pass side one i stuck directly to a flat surface on the inner fender, inside the covered headlight "back" area. i would have done the same for the driver side but the abs pump was in the way.
        • Ryan Stewart
          I Love Miatas
          • 8978
          Mine also came with this crazy nazi glue that I'm pretty sure I couldnt pull off if I wanted to.
          If you look up by the washer bottle you can see where I stuck mine:
          Im now E30less.
          • royalflush313
            • Mar 2004
            • 2070
            http://photos.imageevent.com/rstewar...large/rad3.jpg
            ^^ thanks for the ideas.
            I think maybe I will ziptie the passenger side ballast to the headlight bucket (as long as it doesn't interfere with the cover).
            I velcro-ed the driver's side up against the fender, and also it's wedged under some wiring, so i think it should hold pretty well.
            ~ Go Canucks Go! ~
            • parkerbink
              • Jun 2004
              • 10137
              Pass side ziptied between the high & lowbeam on their carrier driverside double side taped to the side of the inside of the fender inside the plastic cover.
              • Low Level E30
                • 1646
                Did you mount it in the same place on both sides... ?
