No Left side turn signal
  • Skunkworks
    • Sep 2012
    • 436
    I just noticed that i can hear a tick but there is no tail light or indicator light showing up when the left blinker is on.
  • jeffnhiscars
    • Jun 2011
    • 6011
    Assuming by "tail light or indicator light" you mean the front and rear signal lamps,I just fixed the same problem yesterday (only on the right side).
    Bottom line was the blue\black wire to the switch had a break in it so I desoldered it, spliced in & shrink wrapped about 3 inches of new wire and its as good as new. Since yours is left side the blue\red feeds the lights so check for on\off juice at the switch terminal. That will tell you if its the switch or a wire to track down.
    Alice the Time Capsule
    • Skunkworks
      • Sep 2012
      • 436
      [quote=jeffnhiscars;3638650]Assuming by "tail light or indicator light" you mean the front and rear signal lamps,I just fixed the same problem yesterday (only on the right side).
      Bottom line was the blue\black wire to the switch had a break in it so I desoldered it, spliced in & shrink wrapped about 3 inches of new wire and its as good as new. Since yours is left side the blue\red feeds the lights so check for on\off juice at the switch terminal. That will tell you if its the switch or a wire to track down.[/quote
      I meant dash light, But this is very useful information, I will take a look tonight. Thank You
      • Benito_URGOVKURUPTS
        • Apr 2013
        • 25
        not to intrude but im having the same problem where would those wires be located? in the steering column the ones that lead up into the actual turn signal switch. so would i need to pull off the lower dashboard thing to take a look at those wires?
        • Herr Faust Schinken
          • Feb 2012
          • 3580
          cluster light probably burned out
          88 325is Five Speed
          Lachssilber
          • nickmcc92
            • Dec 2012
            • 442
            Did you try clicking it downwards
