hid problem....
  • ///digitalme
    • Dec 2009
    • 2088
    hid problem....
    I recently bought a set of depo smileys...
    installed an hid kit on them...my problem is when I turn the headlights they don't stay on, sometimes one stays on, sometimes the both shut off....
    it takes me about 6 tries for them to stay on and warm up, also noticed at times either one flickers, went back to where I bought them they gave me new bulbs...still the same thing..
    contacts are good, no blown fuses. anything I can check? ballasts are good
  • ///digitalme
    • Dec 2009
    • 2088
    i installed a 35w 6k kit..
    • Blackout
      • Apr 2011
      • 4130
      Could be a faulty ballast. Get new ballasts.
      » PARTS FOR SALE
      » TRANSACTION FEEDBACK
      • ///digitalme
        • Dec 2009
        • 2088
        Thanks for the reply bob. I'll try to source some good ballast. The ones I got are on a budget once I fix my car I'll get good ones. For now I'll go change the ballast see what's up
        • series88
          • Nov 2011
          • 1231
          Happened to a buddy. His remedy was to rev a bit to give it more juice. Weird.
          • IRON-E
            • 16548
            Maybe old headlight relays.
            @IRON-E30 aka Edwin:D
            • ///digitalme
              • Dec 2009
              • 2088
              Ok just tried that and I revved the car and lights got brighter?
              They get brighter when I drive. If I stop or at idle they aren't as bright. I'll check those relays
              • series88
                • Nov 2011
                • 1231
                you might have the same prob he did. He ended up replacing alternator and all was great.
                • Eric
                  • 5142
                  Don't buy DDM HIDs.
                  • ///digitalme
                    • Dec 2009
                    • 2088
                    not ddm though....but similar a little less crappy
                    • spike68
                      • Apr 2009
                      • 1185
                      it sounds like something with the alternator. the ballast may not be getting enough juice. id go get your battery and alternator tested.
                      I don't even own this car anymore, but I'm too lazy to change the picture.
                      • Cabriolet
                        • 9620
                        Originally posted by Eric
                        Don't buy DDM HIDs.
                        been rocking my DDM's for almost 3 year. not one issue. bulbs lasted 2 year before getting blue, 55W ballasts still rockin
                        Much wow
                        I hate 4 doors
                        • sweet6e30
                          • Feb 2011
                          • 531
                          agreed 55w 12 v is the way to go. Been 3 years here too and not one prob.
                          my build here ---> http://www.r3vlimited.com/board/show...ht=lemans+blue
                          • blazinxpk
                            • 839
                            if you swap in regular non-hid bulbs is there still a problem?
                            lights getting brighter with higher rpm seems to be a voltage drop issue. check all your electrical connections that have to do with your battery. make sure they're clean(no corrosion) and tightened down.
                            if issue still occurs then like ^^spike68 said, i would get the battery and alternator tested to ensure they are performing correctly.
                            • ///digitalme
                              • Dec 2009
                              • 2088
                              brand new battery, I bought it 3 months ago...had the alternator tested when i bought a battery...so they have been working fine (yesterday and today) but l have the issue with turning them on, sometimes one turns on either side, I don't have regular h1 bulbs, but didn't have a problem with my ellips, or sealed beams...will get some regular h1 bulbs this week and see if I still have the same problem...
                              thanks for the input...its just concerning....
