Fog High and Low
  • dubtechnic
    • Aug 2012
    • 63
    Fog High and Low
    How do I go about wiring relays to make not only high and low come on when high beams are activated but for my fog lights to stay on as well. I did a sealed beam to depo smiley conversion. I hate that the fogs turn off with high beams as I still like seeing the side of the road for deer and currently I have no real high beam since my lows shut off when high is activated. Help is there any easy write up for this?
  • dubtechnic
    • Aug 2012
    • 63
    Bump still wondering
    • bmwguy325is
      • May 2011
      • 1262
      Yes there is a write up and I found it back in the day when I bought Hella smokes.....
      sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
      The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
      • JasonC
        Site Manager
        • 14451
        Read this thread below. All it is, is a wire to relay to relay.
        1992 BMW 325iC
        1978 Chevrolet Monte Carlo
        • dubtechnic
          • Aug 2012
          • 63
          It turns out I read the diagram wrong and ended up jumping the wrong pins :tsk: It now appears that neither my headlights, foglights, high beams, power windows, and heated seats are working. Put in all new relays now i'm pretty concerned with what damage has been done. 30 minute DIY is now turning into a headache. Any help MUCH appreciated
          • ELVA164
            • 4861
            Nothing works even after replacing the relays? Any blown fuses? What did you jump?
            • dubtechnic
              • Aug 2012
              • 63
              It was pins 30 on K3 and k7 relays I believe. All fuses are ok and I replaced all the relays. Still no luck.
              • dubtechnic
                • Aug 2012
                • 63
                Bump, anyone?
