What headlights?
  • duval7
    • 77
    What headlights?
    Can someone give me a breif discription on headlight options? I have an 88 so it has US ellipsoids from what i can tell. I would like to get a smoked headlight look but i still want factory quality. What should i get and how much should i look to spend? I found these but most of this stuff is crap so that why i am asking you guys. http://www.ebay.com/itm/84-91-BMW-E3...#ht_5861wt_932
    Thanks for the help.
  • blazinxpk
    • 839
    you will not get factory quality from "replacement" lights, such as the DEPO ones that you posted.
    you have a few options:
    1) smoke the current lights you have.
    -use smoked lamin-x film. this method will decrease light output by some percentage due to a film now being in front of the lens. this decrease might be very minimal, and possibly not visible.
    -use this method to smoke the lights: http://www.r3vlimited.com/board/showthread.php?t=94540 though i am not sure if this method works on non-smiley lights.
    2) buy actual hella smoked lights. this option will be the most expensive. real oem smoked light are a lot of money.
    3) buy the depo lights you posted. they have the smoked look, but have slight visual differences compared to euro-smileys. this option will not have the factory quality that you are looking for, though many people do use this option because they are fine with the quality.
    • FLG
      • Sep 2011
      • 3165
      As stated, you basically have 3 choices, live with the ones you have and smoke them. Spend 500+ on OE new lights, or cheap out and buy DEPO's
      I have depos and HID's from miromoto. I always get asked how they are...well theyre nowhere OE quality, but theyre no where OE price. They work good enough for me, though if i had the cash id have went with some new hella's but its a track rat anyways so it really didnt matter.
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
      • bmwguy325is
        • May 2011
        • 1263
        Im glad I bought my smokes when I did. I got them for $300 from turner a long time ago........
        sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
        The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
        • duval7
          • 77
          My headlights have "Hella" printed on them. Are they the H4 Hella upgrades that I have read about? Are they the middle of the road and the euros with the smiley considered the best option? I may just try the tinted film and see how it turns out.
          • Holland
            • Nov 2008
            • 7178
            Hella and Bosch make OEM lights. If they have the ellipsoidal housings, then they aren't H4's.
            Originally posted by DEV0 E30
            • blazinxpk
              • 839
              projector/ellipsoids:
              -US
              -Euro
              Reflector:
              -sealed beams
              -H4 conversion
              so you either have projector or reflector housings. and within those categories it would be one of the two.
              • yahh
                • Aug 2012
                • 800
                I'm running the depos but retrofitted with morimoto h1 projectors. Amazing light output but pretty expensive.
                s50 86 325e Project
                S50 - BBS - Recaro - BC Coilovers - Morimoto H1 Retrofit
                Feedback Thread
                • duval7
                  • 77
                  I googled these and didnt come up with anything for the E30. Do you have any links? So from what you guys are saying i have the US spec elips. which are the worse option as far as light out put?
                  • Holland
                    • Nov 2008
                    • 7178
                    US Ellipsoids are probably among the best if not the best option. Although I hear Hella H4's are a bit better. Worse option are US sealed beams.
                    The difference between US and Euro are the beam cut off patterns.
                    • MPLFoster
                      • May 2013
                      • 1490
                      pics of retro/output?
                      form.follows.function IG @mplfoster
                      • yahh
                        • Aug 2012
                        • 800
                        Pics of lights in my project thread. I'll get some output picks when I get a chance.
                        s50 86 325e Project
                        Feedback Thread
                        • ELVA164
                          • 4861
                          Another possible option is to make your own cross-hatch and install it into the buckets OEM-style. There was a thread somewhere about how to do that...
                          Here it is: http://e30tech.com/forum/showthread.php?t=52494
