What voltage do the license plates light get?
  • azndeugene
    • Sep 2013
    • 192
    So currently my license plate lights don't work. I measured them last night and saw they were getting 0.7V...I get the feeling it should be seeing 12V? Would the wiring be so old that it's providing too much resistance? I'd love to get these working and put some LED bulbs in there :):)
    1986 325
    1988 325is 2.7 Stroker
  • LJ851
    • 7919
    12v, just like it says on the bulbs.
    Lorin
    The M30 is God's engine.
    • Todd Black 88
      • Oct 2007
      • 3449
      You are measureing with a digital volt meter, that's why you read .7volts. You really have nothing.
      Originally posted by codyep3
      I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
      2001 silver/Blk 325 cabby. SOLD
      2002 325xit Sil/blk. SOLD
      2010 F650gs twin
      • azndeugene
        • Sep 2013
        • 192
        Ok so I understand that much but I'm wondering what would be the cause of this voltage drop
        1986 325
        • Todd Black 88
          • Oct 2007
          • 3449
          It's not voltage drop, you have zero voltage there. Voltage drop would show some voltage, and you don't have that.
          This means either the wire is damaged/cut, or some other damage that is not allowing the power to get to the lights.
          2010 F650gs twin
          • azndeugene
            • Sep 2013
            • 192
            This means either the wire is damaged/cut, the brake switch is faulty, or some other damage that is not allowing the power to get to the brake lights? FUSE?
            Why do you refer to the brakes? Are the license plate lights tethered to the same wiring as the brakes?
            All fuses have been replaced a couple months ago. That's the first place I check.
            1986 325
            • mitchlikesbikes
              • Dec 2013
              • 858
              brake lights and license plate lights run on separate power. unfortunately you might have to trace some wires and continue searching for where the power stops. there is a splice in the wiring that sends power to the plate lights near the middle of the door area on the main driver side harness.
              also, look into jumping the power around your active check relay to see if that is causing the issue. the active check relay mounts near the power antenna in the trunk. e30 wiki has wiring diagrams for active check that will tell you which wires are the power in for the plate lights and which ones take the power from the relay to the bulbs. if i remember right there is only one power line in and out and it just splices into two after the relay to supply power to both bulbs
              IG: @mitchlikesbikes
              • azndeugene
                • Sep 2013
                • 192
                Thanks mitchlikesbikes! That was most informative. Im hoping to tackle this little problem this weekend and I guess since ill be near the antenna I might as well replace my broken mast too >.>
                1986 325
                • Todd Black 88
                  • Oct 2007
                  • 3449
                  Sorry, brain fart. I had brake lights on my mind.
                  2010 F650gs twin
                  • DER E30
                    • Sep 2013
                    • 2349
                    Did you check at the wires or at the tabs where the lights click in at? My bulb holder tabs had a bit of a bad connection that I fixed with a soldering iron...
                    -Christian
                    • azndeugene
                      • Sep 2013
                      • 192
                      I removed the lighting fixture and measured at the spade connector. They seem to be on their pretty solid.
                      1986 325
