Euro Smiley question
  • 603Racing
    • Dec 2010
    • 612
    Are the glass lenses removable/replaceable? My right side low beam was shattered, have no idea how. Do I have to replace the whole low beam on that side or just the glass lens?
    90 325i DD/Track
    03 Durango 5.9
    Originally posted by e30mpg
    It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
  • shameson
    • Jun 2012
    • 1507
    I have to do the same thing. Should be able to heat at a low temp enough to break down the adhesive holding the lens on. I've heard some people put it in the oven but idk what temp and for how long
    '84 Alpine 325e (Gone)
    '91 Alpine 318i (Gone) Click Here
    '92 Alpine 325i Cabrio (Gone) Click Here
    '91 Alpine 318is
    • ELVA164
      • 4861
      You can bake the whole light on low heat for 10-15 minutes to soften the adhesive, then gently pry it off with a plastic wedge/paint scraper. I don't remember the exact temp but you can find it by searching. Someone else will have to chime in about what to use to re-seal the light.
      • 603Racing
        • Dec 2010
        • 612
        Finding a lens would be the other challenge. All I've been able to find is whole assemblies.
        90 325i DD/Track
        03 Durango 5.9
        • rav320uk
          • Jun 2004
          • 1337
          180 degrees C, for about 3-5 minutes on the centre shelf.:D
          If you have bought items from me, please leave feedback below.
          If you are a BUYER, Check My Feedback.:up:
          http://www.r3vlimited.com/board/showthread.php?t=183860
          Check out my Euro Build Thread
          http://www.r3vlimited.com/board/showthread.php?t=215557
          • raudonis
            • Jan 2013
            • 184
            Heatgun also works, just be patient and careful.
            My transaction feedback on r3vlimited :):Clickety click
            • e30m3s54turbo
              • Jun 2010
              • 3284
              Rav has taken the lenses off more than I can dream of to counting.
              • AndrewBird
                The Mad Scientist
                • 11898
                I removed the lenses on mine to smoke them. 10-15 minutes in the oven at 350º F worked great for my. I used a sharp pointed awl to get under the lens where the plastic has a notch.
                • Jaxx_
                  • Dec 2009
                  • 1880
                  don't leave them in too long, otherwise you'll be reshaping plastic or buying new headlights.
                  • ky0u
                    • Dec 2012
                    • 808
                    I did it in the oven as well. You might have to reheat it a few times along the way
                    Web Designer / Front End Developer
                    My Portfolio & Website
                    IG: @w_illriderz
                    • ELVA164
                      • 4861
                      So what do people use to reseal? I was thinking of doing this to clean my low beams but want to make sure they would be 100% sealed when I was done.
                      • rav320uk
                        • Jun 2004
                        • 1337
                        Lol.
                        To reseal, use a High Temp Silicone Black sealer.
                        • ELVA164
                          • 4861
                          Lol.
                          Oh, like black RTV?
                          • raudonis
                            • Jan 2013
                            • 184
                            Factory sealant is white, using black sealant will give different look between the factory mounted lenses and the one you are fixing. Ask me how I know
                            • rav320uk
                              • Jun 2004
                              • 1337
                              Factory sealant is Grey.
                              But using Black isn't noticeable as the rings hide whatever colour is used.
