Changing reverse light wiring harness, but...
  • optimusp517
    • Oct 2005
    • 797
    Seems like a plug and play, but what do I need to watch out for when I change it?
    I'm confused cause how does the reverse light work with just the wire, how is it triggering the reverse light is my questoin when you put it in reverse.
  • fretburnr
    • Jan 2005
    • 1496
    there's a reverse light switch screwed into the trans case (assuming manual trans)... when you put the car into reverse, the fork in the trans pushes on the switch nub, closing the circuit. polarity should not matter.
    Jay
    • AndrewBird
      The Mad Scientist
      • 11892
      If it is a one wire setup, then the switched is grounded through the transmission. Basically the switch grounds the reverse lights on and off.
      • fretburnr
        • Jan 2005
        • 1496
        it was two wire in my car, getrag 260
        Jay
