Low beams so dull
  • e30onBBSs
    • Dec 2014
    • 1347
    Low beams so dull
    Hey r3v I have 9006 bulbs in my e30, I think they aren't supposed to fit but it looks like they've been ground out or something to fit. They seem to function fine, but they are worthless for seeing at night. Is it because they are a cheap bulbs? Does different bulb size affect aiming? I've been working all day and this is the only problem I've encountered so far that seems like a dead end. My high beams are probably comparable to others' low beams, could I just aim the low beams but roll with the high beams on all the time because they are as bright as modern day lights?
    BMW tech
    Umass Amherst
    05 wrx sti
  • ELVA164
    • 4861
    Uh...so you have U.S. ellipsoids? Are you saying someone put high beam (9006) bulbs in your low beam (9005) buckets? If so, that's no bueno. If the light output seems very dim, it could be a variety of things. The reflectors in the lights could be cloudy or dirty, the glass could be cloudy and/or sandblasted from road debris, the gauge of wire to the lights could be too small, the wiring might not be sufficiently grounded, the bulbs may be off-brand or old, the adjustment could be (and most likely is) off...no matter what, don't drive with high beams on. Dim or not, they point right at other drivers and that's a safety hazard.
    • e30onBBSs
      • Dec 2014
      • 1347
      Thanks ELVA16! I guess my first step is to get some 9005's and check all of those things. I read about aiming lights and it said to aim the hi-beams and low beams are aimed differently, the hi's are obviously higher so it illuminates up. If I aim the hi-beams to the same height of the low beams, so they will not be in other's eye is that fine? It's not inspected yet so no one is getting blinded :D
      BMW tech
      Umass Amherst
      05 wrx sti
      • e30onBBSs
        • Dec 2014
        • 1347
        Location Qty Specs Generic Sylvania BMW Comments
        Headlights - Sealed Beam, Low 2 35/35W H5006 H5006 63121468226
        Headlights - Sealed Beam, High 2 50W H5001 H5001 63121468272
        Headlights - US Ellipsoids, Lo 2 51W HB4 9006 63217160786
        Headlights - US Ellipsoids, High 2 60W HB3 9005 63217160785
        Headlights - Euro Ellipsoids, Low 2 55W H1 64150 63217160777
        Headlights - Euro Ellipsoids, High 2 55W H1 64150 63217160777
        Headlights - Euro Ellipsoids, City 2 5W W5W 2825 63217160797
        Fog 2 55W H3 64151
        Why does this say 9006 if they don't fit, and it says 9005 for hi beams?
        BMW tech
        Umass Amherst
        05 wrx sti
        • nick_318is
          • Mar 2013
          • 115
          Swap out for a Hella h1/h4 combo.
          • agent
            Vice Grand Pubaa
            • 7960
            Again, do not do that. Isolate and address the actual problem. Don't create another one by using some workaround. Start with replacing the low beam bulbs and aiming them correctly.
            If you want to upgrade to an HID kit, the ones Halston sells are very good and won't break the bank:
            Originally posted by kronus
            • M-technik-3
              • 18946
              Clean the contacts and make sure you are seeing 12V at the lights. Are your lenses pitted? They will defuse the amount of light projected to the road.
              • e30onBBSs
                • Dec 2014
                • 1347
                http://www.r3vlimited.com/board/showthread.php?t=323967
                Thanks agent!
                THanks m-technik! I will get to work after school today
                BMW tech
                Umass Amherst
                05 wrx sti
                • e30onBBSs
                  • Dec 2014
                  • 1347
                  I'm very close to getting the h4's. Will I be able to pass inspection? They are not DOT complaint, but I feel like no one would know/ care?
                  BMW tech
                  Umass Amherst
                  05 wrx sti
                  • DRTSRFR
                    • May 2008
                    • 1836
                    ...and...How to aim your headlights...
                    Suspension tips here...
                    http://www.r3vlimited.com/board/album.php?albumid=757
                    • MPLFoster
                      • May 2013
                      • 1490
                      http://www.danielsternlighting.com/tech/aim/aim.html
                      +1
                      Really good info here.
                      form.follows.function IG @mplfoster
                      • M-technik-3
                        • 18946
                        Most would not even notice the difference.
                        • Mo Brighta
                          • 433
                          Headlight problems
                          Ditto on that, it is NOT a simple matter of aiming highs up and down, because the distribution patterns of high and low beams in decent lights are totally different. Highs have no restriction on glare above a certain elevation, because they are supposed to light up everything when no other driver is within sight. Lows have a very specific function and performance profile including glare restrictions above the 'Cut-off' elevation, which is why there are specific aiming instructions (which could use some revision in the US, but that's another topic). Daniel Stern is a great resource, we talk alot.
                          9005 is the bulb number for high beams, also called HB3. 9006 is for ellipsoidal lows, also called HB4. The highs usually have a slightly higher wattage and output, and are made to fit high beam housings ONLY. And yes, filament location is critical to good lighting performance. Headlight bulbs are not interchangeable for the most part, though there are a few exceptions like the 9011 high beam and 9012 low beam lamps from Philips. Those are new, and use HIR technology to make LOTS more light - but they MUST be adapted to the light housing to work effectively. And HIR is NOT HID. HIR is for Halogen Infrared Reflector lamps, they have filaments, and a special coating inside the glass envelope to reflect heat onto the filament for more light. HID is for High Intensity Discharge, a plasma discharge based lamp, it has no filament.
                          If your bulb has been 'ground down' by someone, I suspect there was experimentation going on. Since you complain of totally inadequate light performance, you clearly still have problems to solve.
                          Here is a true story - my wife bought a car that used H7 in the highs, but I couldn't tell if they were on because there was no significant difference in light on the road with them on or off. I chalked it up to poor lighting design, and because I almost never drove her car I left it alone. Eventually it got under my skin so I took a close look - the lights were connected, the bulbs were glowing, but practically NO LIGHT made it onto the road. Turns out the bulbs were in their sockets, but neither of the spring hold down clips had been secured to hold them in place against the flange, so the filaments were out of place -- by a few millimeters! This misalignment was enough to make them totally useless.
                          It seems you are new to the car, so I'm glad you are seeking to learn about it here, bravo! Hope you can resolve this quickly and easily. If the lights are in decent shape physically and the lenses not too badly pitted, maybe a pair of high performance lamps like the 9012 will do the job for you. If they are trashed, then a decent pair of properly fitted Halogen reflectors like the Hellas may be the best answer.
                          Good Luck, and many happy miles!
                          Andy says "Be Seen, and Not Hurt!"
                          Lighting Upgrades front and back for 2002, E3, E9, E10, E12, E21, E23, E24, E28, E30, E32, E36, E39, and more.
                          Tail Light Improvements keep them off your tail.
                          Headlight protection saves headlights from breakage.
