Power Window Switch Removal?
  • E30X5
    • Mar 2015
    • 30
    Hello... Need to change a couple bulbs in the switches. What's best way to remove the switches from center console? I assume disconnect... But then do I pop them up?
  • george graves
    • 19996
    Remove shit knob (just yank on it - but don't punch yourself in the face) - remove boot. Then you can reach in a pop them up.
    Originally posted by Matt-B
    • E30X5
      • Mar 2015
      • 30
      Thanks!
      • 15Michaeljoseph
        • Aug 2013
        • 1693
        you can just pull the boot up without taking the whole knob off, if you're not feeling like risking knocking yourself out :)
        --Mike
        (OO=[][]=OO) For Life
        • E30X5
          • Mar 2015
          • 30
          Lucky the boot is not in place yet after having the auto swapped for 5spd.... but Yes, I'll take caution in the future -- thanks!
          • Semblance
            • Jan 2011
            • 433
            What bulb goes in there anyway? The 2721 seemed not to fit IIRC
            '89 lachssilber vert - Frau Blücher
            '84 alpine 2dr - gone to the great beyond...
            '00 titanium 4dr e46 - bricked
            • E30X5
              • Mar 2015
              • 30
              Finally found correct replacement bulbs - Micro Lamp 7219
              • Semblance
                • Jan 2011
                • 433
                Awesome! Have you replaced them? How do the wire leads install, it's been years since I opened up a switch. Do they just fold over and stuff the bulb in?
                • E30X5
                  • Mar 2015
                  • 30
                  There's a YouTube video - search BMW Window Switch Light Bulb Repair
                  • Semblance
                    • Jan 2011
                    • 433
                    That's great! Thanks. Here's a link to the video, just dumping it here so I can find it when I need it ;)
                    • george graves
                      • 19996
                      Here, I embedded it for you....
                      Just FYI - for a little bit more trouble you can upgrade to e36 switches (that most all use LED's) - They are much more modern looking, and flow nicely with the interior (not to mention they feel soooooo much better)
                      If you have some money, you can upgrade to one touch versions of the e36 switches. Some jack-ass on here sells them from time to time. ;)
                      • rcsoundn1
                        • Nov 2012
                        • 3361
                        Is that bulb used in all the switches? I need to replace a defroster switch bulb
                        • Semblance
                          • Jan 2011
                          • 433
                          Defroster and hazard use 2721
                          George, I drool over those. Someday.
