E34 Headlights on E30
  • volgapower
    • 161
    does anybody know wether E34 headlights fit in E30 eurogrills????
    i found smoked ones from E34...
  • kylebes1
    • May 2004
    • 2804
    e34 headlights suck
    • volgapower
      • 161
      KYLEBES1 i know they suck, but they are cheap, and i cant find any smoked E30 headlights in my city
      • NickP
        • 257
        They lights themselves fit but you'll need to proper e30 mounting plate. The spacing of the mounting plate of the e34 doesn't work with an e30.
        • volgapower
          • 161
          y mean the iron frame behind the lights, where they are fixed???
          • ZinRot325i
            • 291
            The lighting quality isn't good because the assemblies become shot over the years. The reflective surface on the back of the light gets burnt off and charred. You can disassemble the lights, clean out the inside, and respray the burnt out areas with a 'chrome' paint to get back some of the lighting.
            You need the plastic (in europe they also had metal) 'buckets' that hold the lights in place.
            Wait, I see you're in europe....your lights should be decent if they have the smiley cutouts.
            :wgaf:
            • NickP
              • 257
              Yes - but if you're talking about US ellipsoids, then you'll need the plastic US ellipsoid frames from an e30. If you're talking about the euro spec ellipsoids then you'll need the euro spec ellipsoid frames from an e30.
              I think the metal frames were only used on the sealed beam cars.
                • 34847
                Originally posted by kylebes1
                e34 headlights suck
                huh? E34 ellipsoids are identicle to E30s, aside from the mounts.
                • ZinRot325i
                  • 291
                  For the euro lights, one manufacturer, Hella I think, used metal frames, and Bosch used plastics. Or something like that.
                  He's not from America, he's from Tbilisi, Georgia, the former soviet republic. So he probably doesn't want US ellipsoids.
                  :wgaf:
                  • NickP
                    • 257
                    I've had both Bosch and Hella the frames are both plastic on them.
                    • ZinRot325i
                      • 291
                      My bad...sorry.
                      :wgaf:
                      • NickP
                        • 257
                        My bad...sorry.
                        Nothing to be sorry about :p
                        • volgapower
                          • 161
                          yes u are right, i am from europe... i found brand new smoked E34 ellipsoids for sale, they are made in turkey and are lower quality than hella but they are great... so should i buy them? are they same size that are E30 lights (diameter)?? fixing is no problem, i can weld the frame and make appropriate holes in order to fix them... so do i buy them or no?
                          • MrK
                            • Jan 2006
                            • 709
                            As far as what I've seen, it's the Bosch lights that tend to have metal frames on them. I know because my car had one Bosch side and one Hella side on it before I replaced the set with smoked Hellas from Germany (credit Mikeedler:))
                            This is your M20 on steroids:
                            • NickP
                              • 257
                              Weird my euro headlights are Bosch - they have plastic frames. I had one frame break in an accident and AC Nico was nice enough to send me a replacement frame. It was Hella and was plastic as well.
